01-29-2017, 22:13 | #1 (permalink) |
Junior Member Join Date: Oct 2010 Location: Serbia
Member: 1424755 Status: Offline Thanks Meter: 1 | n95 8gb flash problems |
01-29-2017, 22:33 | #2 (permalink) | |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
Nokia Firmware MrCrab.Net ----------- install nokia conectivity drivers for usb flash then try to flash if you have fbus cable then its easy to remove user code without flashing | |
The Following User Says Thank You to chand_gee For This Useful Post: |
01-29-2017, 22:43 | #3 (permalink) |
Member: 1424755 Status: Offline Thanks Meter: 1 | on back ,product is 0558787 (this is some UK, but i want some EURO or Euro Balkan) but i cant find firmware on that website i dont have fbus i already have nokia conectivity driver. i go to jaf-bb5-check manual flash,dead USB, use ini -find rm-320 -MCU,PPM and CNT change color to green - flash (then ignore 2 warnings) Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... Failed to backup CRT... Detected P-KEY: 9000AAC9 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Not found!!! Last edited by aca 1; 01-29-2017 at 22:49. |
01-31-2017, 02:12 | #4 (permalink) | |
RM-320_EURO_35.0.001_v7.0_N95-8GB.exe check this link RM-320_EURO_35.0.001_v7.0_N95-8GB - Download - 4shared ----------------------- make sure usb cable original clean usb conector from phone press flash button switch off phone conect usb cable put usb cable press power button -------------------------- | |
02-03-2017, 22:05 | #6 (permalink) |
Member: 1424755 Status: Offline Thanks Meter: 1 | Is it possible to flash with jaf with lock code ? when i puch power on button jaf cant find phone.phone is start up nokia logo and that i must insert lock code.I use original nokia dke-2 usb, maybe i must try some different jaf version? or try some firmware with phoenix |
