-   Nokia Base Band 5 ( BB-5 ) (http://forum.gsmhosting.com/vbb/f299/)
-   -   N95 8GB mass memory not available SURE SOLUTION (http://forum.gsmhosting.com/vbb/f299/n95-8gb-mass-memory-not-available-sure-solution-756063/)
DEEPAK_ATOZ 05-22-2009 16:17
Hi guys,
After a long time on this fault I found the same error even after :mad:
1) Flash:mad:
2) update latest file:mad:
3) reheat hard drive
But the problem solved by changing flex cable, but in one hand set i need to change both lcd and flex .:p
I Done 5 handsets with same
THE PROBLEM SOLVED
TRY AND POST RESULTS
A TO Z
gsunny 05-22-2009 17:33
bro, how is this possible i think there is no connection between MASS memory and flex cable
cell surgeon 05-23-2009 20:01
No idea bro have anybody tested then reply..
Actually i faced the same problem before in 2 sets then at last, i solved it by re-bolling the hard drive ic..
http://forum.gsmhosting.com/vbb/f148/n95-4-mass-memory-not-available-612391/
DEEPAK_ATOZ 05-24-2009 11:36
I also wondered after seen this
But it really works 4 me
you just try to use another fornt from a working set and post result
I hope it will solve your problem
just try
worked for my sets
br,
delchoni 11-28-2009 12:55
need to replace d5200
coolmoney 11-17-2010 10:59
take solution; i"m about to test it, i will post result later //gsmnepal.********.com/search/?q=nokia+n95+8gb+mass+memory+not+available+solutio n&x=0&y=0
Sagitarious 12-08-2010 20:07
I have same problem in my N95 8Gb, I change the 100% working Mass Memory in my mobile, but its not working. I also make the Latest Flash file, but same position.
Sagitarious 12-16-2010 13:55
1 Attachment(s)
Now my problem is solved to do this Jumper 100% tested solution :-
anoopkurumathur 03-04-2011 20:40
hi i can't explain what connection between mass memory and flex cable.
but its a proved solution. I solved successfully.
onchogsm 05-12-2011 15:15
this is not worked for me.
BR. good solution regards
Sagitarious 06-20-2011 09:15
Then you must change the Mass Memory.....
shahidanjum7 03-21-2012 22:31
just replac that small ic it well work fine 10000%
Page generated in 0.26377 seconds with 5 queries
