05-22-2009, 16:17 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: "" I N D I A ""
Member: 349089 Status: Offline Thanks Meter: 112 | N95 8GB mass memory not available SURE SOLUTION After a long time on this fault I found the same error even after 1) Flash 2) update latest file 3) reheat hard drive But the problem solved by changing flex cable, but in one hand set i need to change both lcd and flex . I Done 5 handsets with same THE PROBLEM SOLVED TRY AND POST RESULTS BR A TO Z |
The Following 8 Users Say Thank You to DEEPAK_ATOZ For This Useful Post: |
05-23-2009, 20:01 | #3 (permalink) |
Freak Poster Join Date: Feb 2008 Location: INDIA (chennai)
Member: 698937 Status: Offline Thanks Meter: 85 | No idea bro have anybody tested then reply.. Actually i faced the same problem before in 2 sets then at last, i solved it by re-bolling the hard drive ic.. http://forum.gsmhosting.com/vbb/showthread.php?t=612391 |
05-24-2009, 11:36 | #4 (permalink) | |
Member: 349089 Status: Offline Thanks Meter: 112 | Quote:
But it really works 4 me you just try to use another fornt from a working set and post result I hope it will solve your problem just try worked for my sets br, | |
The Following 3 Users Say Thank You to DEEPAK_ATOZ For This Useful Post: |
12-08-2010, 21:07 | #7 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Saudi Arabia
Member: 615730 Status: Offline Thanks Meter: 256 | I have same problem in my N95 8Gb, I change the 100% working Mass Memory in my mobile, but its not working. I also make the Latest Flash file, but same position. |
03-04-2011, 21:40 | #9 (permalink) |
Crazy Poster Join Date: Dec 2010 Age: 35
Member: 1466194 Status: Offline Sonork: 100.86843 Thanks Meter: 8 | hi i can't explain what connection between mass memory and flex cable. but its a proved solution. I solved successfully. |
The Following User Says Thank You to anoopkurumathur For This Useful Post: |
HELP: N95 8GB mass memory not available | oncedotcom | Nokia Base Band 5 ( BB-5 ) | 16 | 10-06-2010 18:53 |
N95 8gb mass memory not available solution 100% | raseelmsm | Nokia Hardware & Hardware Repair | 22 | 12-07-2009 07:10 |
:::Nokia N95 8GB mass memory not available.100% solution::: | indikait | Nokia Base Band 5 ( BB-5 ) | 2 | 10-02-2009 19:55 |
Nokia N95-8GB-Mass memory not available | mohibr | Nokia Base Band 5 ( BB-5 ) | 3 | 05-22-2009 16:51 |
N95 8gb mass memory not available | coolmax | Nokia Hardware & Hardware Repair | 0 | 01-01-2009 17:50 |
