N95 dead after flashing with Phoenix I try to flash my N95 with phoenix via usb cable,but now my phone is dead.Flashing was stop opn 20 %.NOw only shows on the display Nokia and nothing hapend.I try to flash again with phoenix but nothing.Can you help me please. TX |
sorry No experience on phoenix.....i satisfy with Jaff |
In Phoenix go to Manage Connections and choose No Connection. Then you will notice that Scan Product is dissabled, so you choose Open Product and scroll to N-95. You will see the N-95 Product shown in the bottom of Phoenix. Now go to flashing- Firmware tab and small box will appear on the left side. Now push the small box and choose desired Product code and software should appear in the other box. Then tick dead phone usb flashing. Press Flash (You should see adl loader and other drivers detected under found new hardware and should start Flashing. BR |
ur solution is in mt box br |
I try allready Quote:
which version of Phoenix are you using |
version of phoenix I use Phoenix Service Software 2006.44.6.163. |
thats your problem , u must use the latest version of phoenix , 2007 , thats why the flashing stopped, are you using cracked phoenix or fls4 to run phoenix |
New major data package version 2.0 has been released for RM-159. Before installing product data package, please install Phoenix Service Software version 2007.4.6.170 or later. Do not use this data package with previous Phoenix releases. Software downgrade is not allowed, due to BB5 security. In case older software is flashed, the phone does not boot up. USB flashing doesn’t work if phone cannot boot up. This can be fixed by flashing newer software or the same software that was previously used in the phone. This can be done only in level 3 service using phone specific adapter and prommer. This from Service Bulletin "NEW MAJOR DATA PACKAGE VERSION 2.0 (MCU SW 11.0.026)" |
where can i download this 1.70 version of phoenix? |
Now if only someone can help me out with a detailed guide on gettin this installed so I can upgrade a 6300 and a N95.. |
