08-19-2009, 12:13 | #1 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1067108 Status: Offline Thanks Meter: 4 | N96...all seems ok, but is dead!? When power on it resets on Nokia logo continuosly. The stange thing is that all JAF tests are PASSED and the log seems to be ok. P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Programmi\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Programmi\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Programmi\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Programmi\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.17.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR72_08w50.4 05-06-09 RM-247 (c) Nokia HW version: 1001 PCI version: RFIC version: DSP version: Retu version: 15 Tahvo version: 22 Production serial number: CUB553903 Product code: 0572896 Module code: Basic production code: 0542934 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 3564060209...... IMEI spare to net: 3A 65 04 06.............. IMEI SV to net: 33 65 04 06 02............ LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Programmi\ODEON\JAF\JAF_RM-247.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0572896 Searching for JAF saved location of ini... Checking path: C:\Programmi\Nokia\Phoenix\Products\RM-247\ Searching for default location of ini... Checking path: C:\Programmi\File comuni\Nokia\DataPackage\Products\RM-247\ Scanning ini files... Searching for default location of ini... Checking path: C:\Programmi\File comuni\Nokia\DataPackage\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: C:\Programmi\File comuni\Nokia\DataPackage\Products\RM-247\RM-247_21.003_prd.core.fpsx PPM Flash file: C:\Programmi\File comuni\Nokia\DataPackage\Products\RM-247\RM-247_21.003_001.1_prd.language.fpsx CNT Flash file: C:\Programmi\File comuni\Nokia\DataPackage\Products\RM-247\RM-247_21.002_252.7_prd.customer.fpsx APE Variant file: C:\Programmi\File comuni\Nokia\DataPackage\Products\RM-247\RM247_21.002_001_003_U237.uda.fpsx Languages in ppm: English,French,German,Italian,Spanish,Portuguese Done! Someone can help me??? |
The Following User Says Thank You to petercas For This Useful Post: |
08-20-2009, 08:43 | #3 (permalink) |
Member: 1067108 Status: Offline Thanks Meter: 4 | I do it., but the problem persists. I tried to format FS from JAF and it doesn't recognize the correct fs via FBUS and USB also after full factory settings. I noticed that now the display not shows the text Local or Test mode but whit FBUS cable it seems to go in test or local mode instead of the usb mode that doesn't work! It's possible that the problem was MxKey that i used to erase the phone before full reflash it? |
08-22-2009, 09:32 | #4 (permalink) |
Member: 1067108 Status: Offline Thanks Meter: 4 | I can confirm that the problem was the whoole erase eeprom of mxkey. Now the phone don't starts....only Nokia logo and then white screen. In JAF and MxKey on the display doesn't appears the LOCAL and TEST MODE and it's impossible to recognize and format the FS. (FBUS and USB mode....same problems). I need help, somewhere i reed that after whoole flash eeproom only ENO firmware can recover it.....it's thrue? I hope no because ENO for N96 wasn't yet released and nobody known if it'll be released. There's some ather metod to recovery my phone? |
08-22-2009, 10:08 | #6 (permalink) |
Member: 1067108 Status: Offline Thanks Meter: 4 | I don't think so, because the phone before erasing eeprom works perfectly. But all is possible.....there some way to test the hardware? Thanks! Last edited by petercas; 08-22-2009 at 10:13. |
10-27-2009, 14:22 | #7 (permalink) | |
Freak Poster Join Date: May 2003 Location: turkey Age: 47
Member: 28358 Status: Offline Thanks Meter: 12 | Quote:
N70 Strange All Modes Ok But Set Dead | manishjoshi_bkn | Nokia Base Band 5 ( BB-5 ) | 5 | 06-21-2007 17:35 |
full flashing 8210 works ok... but still dead phone | bengong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 02-09-2003 05:37 |
Gd75 all OK but still dead ! | ficho | Panasonic | 3 | 01-14-2003 19:15 |
Hi to All :-) twoo alcatel dead bf3 and bf4 read all phone ok !!!but not written | CHATAR | BF, BG, TH, BHx Series | 9 | 09-02-2002 22:59 |
outer is ok, but inside dead | CellM@n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-09-2002 11:09 |
