12-18-2009, 08:13 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 691635 Status: Offline Thanks Meter: 25 | N96 Flashing with USB Soluation !! Hello , The Soluation for all over GSM-SHORBAGY Members here .. It is indeed a problem and I had personally and I think it faced many of the members here .And If you will go to Device Manager ;you will see the phone connected sucessfully , But what's problem then ?!! But when you plug your phone to PC it will connect and detect some H/W into phone but it cannot detect one Driver , this driver called :N96 MTP Driver. Code: Loading INI list... Detected P-KEY: 00000000 P-key nokia module version 01.02 Init usb communication... Reading product code... Product Code: 0543900 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-247\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_prd.core.fpsx PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_020.1_prd.language.fpsx CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_098.1_prd.customer.fpsx APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_100.1_prd.uda.fpsx Languages in ppm: English,Arabic,France Done! Backing up CRT... Detected P-KEY: XXXXXXXX P-key nokia module version 01.02 Init usb communication... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\35XXXXXXXX XXX_CRT_backu p_2024211.pm Done! Backup CRT OK! Detected P-KEY: XXXXXXX P-key nokia module version 01.02 Init usb communication... Searching for phone...Found Reading SW version...ICPR72_08w35.1 11.018 Reading battery value...3921 mV Init usb flashing... Reading flashid... CMT: 2C7E0001 <=> SPANSION -> 72NS128N APE: 00000000 <=> Flash -> not detected Verifing ADL communication... Status byte 8 Rebooting to flash mode... Waiting for the phone to reboot... Searching for phone...So what the soluation ?: - N96 MTP USB DRIVER ( You will find it in attachment). - Extract file and setup file :Nokia_Flashing_Cable_Driver.msi - Plug your phone and flash it . Here is log result for phone done sucessfully : Code: 22:01:2009 15:37 -> Detected P-KEY: xxxxxxx 22:01:2009 15:37 -> P-key nokia module version 01.02 22:01:2009 15:37 -> Init usb communication... 22:01:2009 15:37 -> PRESS POWER ON NOW! Searching for phone...22:01:2009 15:37 -> Found 22:01:2009 15:37 -> Sending APE boot... 22:01:2009 15:37 -> Loader version: 00.00.0022:01:2009 15:37 -> -> Revision: 0200 22:01:2009 15:37 -> Patching APE boot step1... 22:01:2009 15:37 -> Patching APE boot step2... 22:01:2009 15:37 -> Patching APE boot step3... 22:01:2009 15:37 -> Sending ape boot... 22:01:2009 15:37 -> APE FLASHID: B1002000 22:01:2009 15:37 -> Sending APE loader... 22:01:2009 15:37 -> Waiting for Update Server to boot... 22:01:2009 15:37 -> Sending CMT boot... 22:01:2009 15:37 -> Loader version: 08.24.0022:01:2009 15:37 -> -> Revision: 0200 22:01:2009 15:37 -> Patching CMT boot step1... 22:01:2009 15:37 -> Patching CMT boot step2... 22:01:2009 15:37 -> Patching CMT boot step3... 22:01:2009 15:37 -> CMT FLASHID: 7E2C0100 22:01:2009 15:37 -> Sending CMT loader... 22:01:2009 15:37 -> Reading CMT papub hash... 22:01:2009 15:37 -> Reading APE papub hash... 22:01:2009 15:37 -> CMT blocks: 398, APE blocks: 3212 22:01:2009 15:37 -> Partition CMT... 22:01:2009 15:37 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_prd.core.fpsx... 22:01:2009 15:37 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_020.1_prd.language.fpsx. .. 22:01:2009 15:37 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_098.1_prd.customer.fpsx. .. 22:01:2009 15:37 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_100.1_prd.uda.fpsx... 22:01:2009 15:37 -> Partition APE... 22:01:2009 15:37 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_prd.core.fpsx... 22:01:2009 15:37 -> Sending APE partition Data... 22:01:2009 15:37 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_020.1_prd.language.fpsx. .. 22:01:2009 15:37 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_098.1_prd.customer.fpsx. .. 22:01:2009 15:37 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_100.1_prd.uda.fpsx... 22:01:2009 15:37 -> Erase CMT... 22:01:2009 15:37 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_prd.core.fpsx... 22:01:2009 15:38 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_020.1_prd.language.fpsx. .. 22:01:2009 15:38 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_098.1_prd.customer.fpsx. .. 22:01:2009 15:38 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_100.1_prd.uda.fpsx... 22:01:2009 15:38 -> Erase APE... 22:01:2009 15:38 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_prd.core.fpsx... 22:01:2009 15:38 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_020.1_prd.language.fpsx. .. 22:01:2009 15:38 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_098.1_prd.customer.fpsx. .. 22:01:2009 15:38 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_100.1_prd.uda.fpsx... 22:01:2009 15:38 -> Write CMT... 22:01:2009 15:38 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_prd.core.fpsx... 22:01:2009 15:38 -> Sending CMT HASH for NOLO 22:01:2009 15:38 -> Sending CMT HASH for KEYS 22:01:2009 15:38 -> Sending CMT HASH for PRIMAPP 22:01:2009 15:38 -> Sending CMT HASH for PASUBTOC 22:01:2009 15:38 -> MATCH cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... 22:01:2009 15:38 -> PAPUBKEYS already sent... 22:01:2009 15:38 -> PAPUBKEYS already sent... 22:01:2009 15:38 -> Sending CMT HASH for UPDAPP 22:01:2009 15:38 -> Sending CMT HASH for DSP0 22:01:2009 15:38 -> Sending CMT HASH for MCUSW 22:01:2009 15:39 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_020.1_prd.language.fpsx. .. 22:01:2009 15:39 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_098.1_prd.customer.fpsx. .. 22:01:2009 15:39 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_100.1_prd.uda.fpsx... 22:01:2009 15:39 -> Write APE... 22:01:2009 15:39 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_prd.core.fpsx... 22:01:2009 15:39 -> Sending APE HASH for X-LOADER 22:01:2009 15:39 -> Sending APE HASH for KEYS 22:01:2009 15:39 -> Sending APE HASH for PRIMAAPP 22:01:2009 15:39 -> Sending APE HASH for SOS*UPDAPP 22:01:2009 15:39 -> Sending APE HASH for SOS+XZIP 22:01:2009 15:39 -> Sending APE HASH for PASUBTOC 22:01:2009 15:39 -> MATCH ape->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... 22:01:2009 15:39 -> Sending APE HASH for SOS+CORE 22:01:2009 15:39 -> Sending APE HASH for SOS+ROFS1 22:01:2009 15:40 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_020.1_prd.language.fpsx. .. 22:01:2009 15:40 -> Sending APE HASH for SOS+ROFS2 22:01:2009 15:40 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_098.1_prd.customer.fpsx. .. 22:01:2009 15:40 -> Sending APE HASH for SOS+ROFS3 22:01:2009 15:40 -> Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-247\RM-247_12.043_100.1_prd.uda.fpsx... 22:01:2009 15:40 -> Rebooting... 22:01:2009 15:40 -> Pooling phone... 22:01:2009 15:40 -> MCUSW: V ICPR72_08w41.2 25-11-08 RM-247 (c) Nokia 22:01:2009 15:40 -> APESW: 12.043 22:01:2009 15:40 -> VariantSW: 12.04312.043.020.112.043.098.1 22:01:2009 15:40 -> Prodcode: 0543900 22:01:2009 15:40 -> DCT4/BB5 counter: 76 22:01:2009 15:40 -> Done! Done ..tested 100% !!! http://www.megaupload.com/?d=E0SLA89A |
The Following 5 Users Say Thank You to reguieg For This Useful Post: |
12-18-2009, 14:11 | #2 (permalink) |
Insane Poster Join Date: Sep 2009
Member: 1109445 Status: Offline Thanks Meter: 5 | peace.. sir do you have solution for n6120 classic? my problem is after i click the flash button and goes like this Verifing ADL communication... Status byte 8 Rebooting to flash mode... Waiting for the phone to reboot... Searching for phone... phone rebooted not in flash mode..So what's the solution ? i've tried to wait 10 -15 minutes, but nothing happen next here's some pics Last edited by madjong; 12-18-2009 at 14:17. Reason: update |
n96 not flash with usb mode on ub | X-TRA | Universalbox | 3 | 02-20-2010 11:22 |
n96 not flash with usb mode nokia mode | X-TRA | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-20-2010 10:05 |
please give me usb drivers for sedbx flashing with usb | haydernaz | HWK | 4 | 04-14-2009 10:05 |
