02-09-2013, 22:31 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: spain Age: 44
Member: 60189 Status: Offline Thanks Meter: 99 | need best configuration sl3 bruteforce pc (2 ati 6990)) 1000w powersuply i7 x980 3,33 Ghz 8gb ram asus p67 mainboard 2 ati 6990 windows 7 home premium 64 bitVersión del paquete de controladores 8.982-120727a-144945C-ATI Versión de Catalyst 12.8 Proveedor Advanced Micro Devices, Inc. Versión de controlador 2D 8.01.01.1253 Ruta de archivo de controlador 2D /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0001 Versión de Direct3D 9.14.10.0924 Versión de OpenGL 6.14.10.11762 Versión de Catalyst Control Center 2012.0806.1213.19931 i use oclhascat 0.10 i had 3 hours left and pc get blocked try it again now 14 hours (max. 1 day 20 hours) still no luck how i can get it faster need perfect configuration please need help Hash.Type....: SL3 Time.Running.: 1 day, 1 hour Time.Left....: 14 hours, 10 mins Plain.Mask...: ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 Plain.Text...: ********0107080704040009030506 Plain.Length.: 15 Progress.....: 656911993405440/1000000000000000 (65.69%) Speed.GPU.#1.: 1811.2M/s Speed.GPU.#2.: 1649.7M/s Speed.GPU.#3.: 1657.5M/s Speed.GPU.#4.: 1619.5M/s Speed.GPU.#*.: 6725.2M/s HWMon.GPU.#1.: 99% Util, 81c Temp, 100% Fan HWMon.GPU.#2.: 99% Util, 80c Temp, 100% Fan HWMon.GPU.#3.: 99% Util, 81c Temp, 100% Fan HWMon.GPU.#4.: 99% Util, 80c Temp, 100% Fan [s]tatus [p]ause [r]esume [q]uit => s Status.......: Running Hash.Target..: 46cc5325e867656c195849553cfa464abe3f4887:003519380 550646900 Hash.Type....: SL3 Time.Running.: 1 day, 1 hour Time.Left....: 13 hours, 40 mins Plain.Mask...: ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 Plain.Text...: ********0903090408020306020606 Plain.Length.: 15 Progress.....: 662636632473600/1000000000000000 (66.26%) Speed.GPU.#1.: 1843.8M/s Speed.GPU.#2.: 1685.0M/s Speed.GPU.#3.: 1682.7M/s Speed.GPU.#4.: 1651.9M/s Speed.GPU.#*.: 6850.0M/s HWMon.GPU.#1.: 99% Util, 81c Temp, 100% Fan HWMon.GPU.#2.: 99% Util, 82c Temp, 100% Fan HWMon.GPU.#3.: 99% Util, 82c Temp, 100% Fan HWMon.GPU.#4.: 99% Util, 82c Temp, 100% Fan [s]tatus [p]ause [r]esume [q]uit => |
02-09-2013, 22:39 | #2 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | in performance - overclock gpu's to the same value: 830MHz both. Try that once. And i perssonal opinion is that 1000w powersuply is less than required. You need 200w more to everything function properly |
02-09-2013, 22:55 | #4 (permalink) | |
Member: 1671934 Status: Offline Thanks Meter: 247 | Quote:
https://www.google.com/search?q=how+...hrome&ie=UTF-8 | |
02-09-2013, 22:57 | #5 (permalink) |
Member: 60189 Status: Offline Thanks Meter: 99 | all are gpu are 830 mhz, memory 1250mhz ... you think i can get a higher result change driver o hashcat ... im now on 67% still no luck ... it take very long what i can do? my configuracion is ok or how i can better result? |
02-09-2013, 22:58 | #6 (permalink) | |
Yes, you can overclock both cards to 950MHz , [IMG]http://1.bp.********.com/-U1FHXVNfDFw/TmhyT-nY5CI/AAAAAAAAAEs/QQYY80Dpc8g/s1600/overclock.png[/IMG] or something like this maybe ????? but prepare for cooling | |
02-09-2013, 23:12 | #9 (permalink) |
Member: 1671934 Status: Offline Thanks Meter: 247 | -Enable crossfire, -950 Mhz both cards, make changes to MHZ on 4 places i think because of double cores. -Me personally use oclhashcat-lite v13 and i am getting best results. similar like this: In Performance, in AMD Overdrive: or this: or even this: And maybe u will get this in the end: |
The Following User Says Thank You to unlock.mk For This Useful Post: |
02-09-2013, 23:22 | #11 (permalink) |
Member: 60189 Status: Offline Thanks Meter: 99 | and you use hashcat 0.13 only o or with mxkey atf ... is my first brute force pc i bought this pc second hand and the owner told me he done 2-3 phones a day... with luck i can do one every 2 days ! ! ! Last edited by movilstore; 02-09-2013 at 23:28. |
02-09-2013, 23:39 | #14 (permalink) |
Member: 1671934 Status: Offline Thanks Meter: 247 | You will, and when you will get 10 codes for 10 phones, then it will be more easier to unlock or Nokias Expirience is mother of success. |
