05-20-2011, 07:06 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | hot news.. ufs/hwk box update relese soon This is the information that I have from Saras about the next update, this list is not final and more could be added before the release is ready, please do not ask when this will be released since I have no info on a release date:- DCTxBB5 1. BB5 products: RM-576,RM-577 (6700s,6700s-1c) added. 2. Local RPL Service Fixed for ASIC 2,5,6,7,11 (UEM_PASW is Correct now) Note: Need Confirm [Readout and Use UEM IMEI] when do [Rd UEM]. 3. [Check Ask/Rpl] Renamed to [Calc Ask/Rpl] as can Calculate RPL now. 4. [Calc Ask/Rpl] Function will Generate Real RPL from ASK file (ASIC 2,5,6,7,11) Note: When Reading UEM, do not Forget Set Right [UEM Changed] Status ! 5. RSA Lock/Unlock for All DCT4+ products (not need Patch) 6. Life Timer added to [PM Edit] 7. DCT4 INFINEON Based Products USB Flashing / UI support added: RH-111,RH-125,RH-126,RM-607,RM-608,RM-643,RM-644,RM-647,RM-653, RM-669,RM-689,RM-704,RM-732,RM-733 (1202,1616-2,1616-2b,C1-01,C1-01.1, C1-02,C1-02.1,1280,1800,1800b,C1-00,C2-00,X1-00,X1-00.1) 8. BB5 RAP3Gv40 Based Products USB Flashing / UI support added: RM-509,RM-510,RM-511,RM-540,RM-598,RM-604,RM-615,RM-638,RM-721,RM-722 (3710a-1,3710a-1c,3711a-1,X3-00,7230-1c,7230-1,5330-1d,6303ci,C2-01,C2-01.5) 9. BB5 RAPU Based Products USB Flashing / UI support added: RM-582,RM-596,RM-601,RM-609,RM-610,RM-627,RM-629,RM-632,RM-634, RM-639,RM-640,RM-645,RM-648,RM-658,RM-659,RM-662,RM-675,RM-682, RM-688,RM-691,RM-697,RM-699,RM-707,RM-718,RM-719,RM-720,RM-749 (Vertu CQ,N8-00,C6-01,E6-00,E6-00.1,X5-01,5230-1d,E5-00,E5-00.2,X3-02,C3-01, C5-00.X5-01.2,E73,X7-00.1,C3-01m,C7-00,6702s,C5-00.1,C7-00b,C5-03,E5-00m, X7-00,C6-01.3,C5-03.2,C5-04.1,C7-00s) 10.BB5 RAPIDO Based Products USB Flashing / UI support added: RM-484,RM-485,RM-486,RM-551,RM-552,RM-559,RM-588,RM-593,RM-594, RM-612,RM-624,RM-625,RM-684 (N86-1,N86-3,N86-5,X6-00.1,X6-00m,X6-00,5230-1,5230-1c,5230-1b,C6-00, C6-00.1,5288,5250) 11.BB5 JUNO (BCM21351) Based Products USB Flashing / UI support added: RM-497,RM-586,RM-614,RM-618,RM-709,RM717 (7020a-2,2710c-2,C3-00,X2-00,X2-01,X2-01.1) LG_GSM 1. Infineon: A110,A130,A133,A133GO,C100,C105,C300,C300GO,C305,C 310,GB220, GB220nGO,GB230,GB280,GD350,GD510,GD510N,GM360,GM36 0i,GM600, GS170,GS290,GS290GO,GS290N,GS390GO,GS500,GS500g,GS 500gx,GS500v, GT350,GT350GO,GT350i,GT360,GT365,GU220,GU230,KF510 ,KF510d, KM380,KM380c,KM380d,KM385d,KM386c,KP500,KP500N,KP5 01,KP502, KP502GO,KP505,KP550,KP570q,KS360,KS365,T300,T310,T 310i,T310N, T315,T315i,T320,T320e,T320g,T325 added. Notes: 1. To See Unlock Codes and Instructions, Press [BOOT] 2. To Flash Dead Phones, Tick [Emerg. Boot] 2. MTK A120,A155,A160,A165,GB161 added. 3. BT Address Write Added for Infineon and MTK platforms. SAMs TRIDENT A127,i626,X475 added (DUNL,IM,FL) OM(SYSOL) T209,T319 added (DUNL,IM,FL,SECT) SWIFT A436,A437 added (DUNL,IM,SECT) Note: For Flashing use A4xxxx_RD files. A516,A517,T229,T249,T339,T349-LTA-USA,T369,T409,T619,T739 added (DUNL,IM,SECT,FL) Added Multi Drive support for TFS Read. SWIFT-AEROFONE Added [Patch MSL] Function to Patch without MCU Part Flashing. T109,T119 added (DUNL,IM,FL) E1080F-IND-MEA-SEA,E1081T-EU-IND-MEA-SEA,E1085F,E1085F-MEA, E1105F,E1150i,E1160i,E1170T,E1172,E1175T-EU-IND,E1178,E1225F, E1225T,E1225T-IND added (PUNL,PIM,FL) Notes: 1.Mixing of EU IND MEA SEA Files causes Blinking or Dead Sets. 2.E1081T EU E2P Image is not Compatible with IND, MEA or SEA. 3.For Cross Flashing Select Model Name Extension by File type. 4.Before Unlock, Info to see Codes or Rebuild IMEI use [Patch MSL] Button or Flash with [Patch MSL] Option Enabled. C3222 added (DUNL,CUNL) Note: C3222 Flashing not Supported yet, use Original Flasher. SWIFT-3G C5010E,E3210 added (CUNL,SECT,FL) QUALCOMM A847,A927,B2710D,C5180,S5520,S5580,S6700T,S6888,T3 59,T479,T749 added. More Versions Support of Hidden Sysinfo models CUNL and UNFR: A706,A707,A717,A727,A847,A887,A897,A927,B2710,B271 0D,S3370, S5530,T359,T469,T479,T559,T659,T749 QUALCOMM+LSI S8500B,S8530 added (FL) BROADCOM S5230N added (FL,CUNL,UNFR,BRP) S5330L,S5750E,S5753E,S7230E,S7233E added (FL) S5250,S5253,S5330,S5330L,S5333 Boot Repair (BRP) INFINEON B3310i,C3200,C3200G,C3200L,C3530,C3530L,E2530,S331 0i,S3350, S3353,S3550,S3550C,S3550L added (CUNL,PUNL,PIM,FL) E1151, Now Possible to Flash Read BIN Dump (Size: 007F0000) Regards, Odia. |
The Following 5 Users Say Thank You to .::Gsm_Srilanka::. For This Useful Post: |
05-20-2011, 07:47 | #2 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
from where you get this information please ??????????? | |
05-20-2011, 08:37 | #4 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 541042 Status: Offline Thanks Meter: 519 | This is the information that I have from Saras about the next update, this list is not final and more could be added before the release is ready, please do not ask when this will be released since I have no info on a release date:- |
05-20-2011, 08:41 | #5 (permalink) | |
Member: 1133072 Status: Offline Thanks Meter: 505 | Quote:
bro what u want to know about this update? | |
05-20-2011, 11:52 | #9 (permalink) | |
Member: 541042 Status: Offline Thanks Meter: 519 | Open you Eyes and read voll Posting Quote:
Soon Soon next year,days blabla Read Orginal Thread, and post not Info Update Soon Odin give Update what inside Update is, and not when Release Close Copy Past Thread, orginal by Productsupport | |
i WANT TO BUY NOKIA BOX !!! | Eric | Wanted Products | 8 | 02-14-2011 13:23 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
