Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-22-2009, 09:33   #1 (permalink)
Member: 41976
Thanks Meter: 33
6300 write pm without sx4 auth on jaf
hello!
i just want to share this solution and hope it can be useful to some members of this forum.
i had a 6300 dead and the blue lights on the 2 sides lights up.i flashed the phone on jaf with version 7.21 and its still the same.
action taken:
1.back up crt.
2.erase phone
3.full flash.then phone switch on but imei is 123456 and phone is contact service.
4.write pm using jaf care.no need sx4 auth(if you back up crt then write pm,it will require sx4 auth)
5.then back up crt to restore imei.
6.finally unlock phone on zulea's free software to remove contact service and phone is alive and working perfectly.
NOTE:IF YOU DONT BACK UP CRT,YOU WILL NEED RPL TO FIX FONE AND IT WILL COST MONEY.
hope this info is useful.
The Following 2 Users Say Thank You to wearephones For This Useful Post:
Old 05-01-2009, 08:15   #2 (permalink)
Member: 15385
Thanks Meter: 9
6300
I have one pcs of 6300 which shows me "contact service"
I try your way how to fix, made backup crt, try to upload pm, but it requires SX4 active. Your pasr at point 3. and 4. I don't understand. Can you explain one more time, step by step how did you do it?
Thanks in advance
After write PM by SX4 AUTH !! but N73 phone start-up-failed contact the retailer reaz.com MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 11-04-2009 15:06
MT cant write PM with SX4 !! but MX-Key succesfully write PM with SX4 !!! reaz.com MXKEY Nokia Flasher and Unlocker (by Alim Hape) 10 07-18-2009 05:37
write pm without Sx4 Server sainesh Nokia Base Band 5 ( BB-5 ) 3 05-19-2009 00:23
Page generated in 0.54895 seconds with 9 queries
