08-07-2009, 07:39 | #1 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Kazakhstan Age: 41
Member: 4374 Status: Offline Thanks Meter: 9 | New 6700c and BT problem. I have 4 brand new 6700 with same problem. When i want power on BT progress bar run and run and BT not turn on, if i press red button phone restart. Flashing and reseting with phoenx and different sw version (7.60, 7.90) not help |
08-07-2009, 07:45 | #2 (permalink) |
Crazy Poster Join Date: Nov 2008
Member: 898710 Status: Offline Thanks Meter: 8 | Check the BT address with *#2820# If BT address is not found then you have to replace the BT ic then flashing the phone. Rgds, |
The Following User Says Thank You to rajdeep_slg For This Useful Post: |
08-07-2009, 08:46 | #6 (permalink) | |
Member: 4374 Status: Offline Thanks Meter: 9 | Quote:
Are you joke? See my first post! and you see this - "When i want power on BT progress bar run and run and BT not turn on, if i press red button phone restart." | |
09-22-2009, 07:03 | #14 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Azerbaijan Age: 38
Member: 68498 Status: Offline Thanks Meter: 152 | I have read somewhere that this is a hardware problem which can be found also in 6303 camera and bluetooth problem.Just rehot and take out the battery connector from the mainboard.Under you will find 4 tracks that must be repaired.One of them is camera and the other is bluetooth,don't know about others.This must help if changing BT ic doesn't help. |
The Following User Says Thank You to systemworm For This Useful Post: |
09-22-2009, 08:13 | #15 (permalink) | |
The Following User Says Thank You to odyssey For This Useful Post: |
New firmware and strange problem | domestik | Infinity-Box | 4 | 11-16-2009 14:04 |
LG u990 IMEI AND BT PROBLEM SOLVED AFTER UNLOCK | GSMMart | FuriousGold | 7 | 04-11-2009 10:03 |
6600 display and bt problem | ameho0102 | Nokia Hardware & Hardware Repair | 10 | 03-02-2008 11:16 |
sms and bt problem on P910i plz need help? | .::Moby World::. | Sony Ericsson | 3 | 10-23-2005 20:48 |
New BOX and some problems | ziko | FuriouS II | 9 | 04-23-2005 16:00 |
