07-28-2009, 08:30 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 749916 Status: Offline Sonork: 1647914 Thanks Meter: 43 | 3110c ui settings failed |
The Following User Says Thank You to kumar_pvj For This Useful Post: |
08-10-2009, 14:07 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Kathmandu, Nepal
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | same problem here flash ok but ui defaults failed, downgrade not possible : it says init local mode failed any solution need it urgent |
08-10-2009, 14:23 | #4 (permalink) |
Freak Poster Join Date: Mar 2006 Location: PAKISTAN
Member: 241662 Status: Offline Sonork: 100.1603988 Thanks Meter: 145 | brother first of all u give to just mcu and ppm. after this ur mobile will go to local mode . then go to cnt .ur problem will be solved. if u r ufs box then ur problem will 100% solved for flashing on ufs hwk box. |
The Following 2 Users Say Thank You to mt mobiles For This Useful Post: |
08-10-2009, 15:57 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: libya Age: 44
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | my brother you must check your cable . is it local mode or no ? in second use jaf box and flash cnt 128 only and see your phone inter to local mode or no if your phone show local mode go to change it test mode and make UI settings |
The Following User Says Thank You to Gsm Benghazi For This Useful Post: |
08-10-2009, 15:58 | #6 (permalink) |
Member: 412609 Status: Offline Sonork: 100.1586824 Thanks Meter: 148 | :: waw :: my brother you must check your cable . is it local mode or no ? in second use jaf box and flash cnt 128 only and see your phone inter to local mode or no if your phone show local mode go to change it test mode and make UI settings |
11-15-2009, 17:08 | #9 (permalink) |
Junior Member Join Date: Dec 2008
Member: 926149 Status: Offline Thanks Meter: 0 | nokia 3110c flashing with ufshwk shows UI defauld faild and init local mode failed 1ST BOOT : C0,07 [Rm-237] [2.0.9.0] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 1BB00114F2367E560DCF7224FD2A332A0AC1AA24 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898981-00006A21, Int NU48F256 CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent Rebooting Mobile pleas help me out with this[IMG]file:///C:/DOCUME%7E1/ujalaa/LOCALS%7E1/Temp/moz-screenshot.png[/IMG] |
11-15-2009, 17:15 | #10 (permalink) |
Member: 926149 Status: Offline Thanks Meter: 0 | Please let me know the solution for nokia 3110c. I have UFShwk. I flashed 3110c with new rm237__07.01.mcusw , rm237__07.01.ppm_s and rm237__07.01.image_s it takes ful flash but UI setting failed. When I turned on the phone the nokia logo shows and phone turn off. |
10-14-2010, 10:52 | #15 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 718146 Status: Offline Sonork: 100.1619088 Thanks Meter: 118 | it is so simple! use mx key and go to quick fix and click on downgrade fixing i already upto 100 times fix this problem |
The Following User Says Thank You to rimjhim For This Useful Post: |
ui setting failed with bb5 | coolmax | HWK | 8 | 06-17-2014 08:45 |
3110c flashing complete ui setting failed please help me urgent | prakash40 | HWK | 22 | 10-27-2010 15:20 |
..:: 2310 flashing complete ui settings failed ::.. | HUM | Nokia Hardware & Hardware Repair | 8 | 06-16-2007 04:51 |
n-gage qd UI setting failed | gsmshare98 | Nokia Hardware & Hardware Repair | 0 | 03-22-2007 14:28 |
1100/2300 UI Setting Failed | Jayrus | Nokia Hardware & Hardware Repair | 2 | 09-06-2006 17:44 |
