06-29-2013, 11:30 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: JESSORE.BD
Member: 1054255 Status: Offline Sonork: BISMILLAH.M.S.CENTER Thanks Meter: 92 | NOKIA-200- SUPERDONGLE_KEY invalid!-HELP MXKEY [FT SCR2000 0], SN: C080418B Using device: USB Phonet Connection status: EHCI:HUB:HUB::USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD__back.RPL" Processing file: rm761__10.60.mcusw Downloading item CODE:rm761__10.60.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.422 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.407 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.954 s Erasing area 0x40280000-0x41A7FFFE ...OK Programming completed in 42.844 s Checksum verified (0xA72F) Processing file: rm761__10.60.ppm_ma2 Downloading item CUSTackage_ma2.ppm_ebl_psi.fls, num block: 1, size: 5.06 MB Erasing area 0x41A80000-0x41F8E276 ...OK Programming completed in 8.969 s Checksum verified (0xDB90) Processing file: rm761__10.60.image_ma2_059J5P6_002 Downloading item CUSTackage_ma2_059J5P6.image.fls, num block: 1, size: 14.13 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 25.109 s Checksum verified (0x3F8D) Total time for flashing process(boot+erase+write) was 6 min 59.187 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 12352E0F Verifying communication to device OK. Phone type: RM-761 (Nokia 200) SW version: V 10.60 20-01-12 RM-761 (c) Nokia Imei plain: 35825904973072-4 Product code: 059K952 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 06150123008027, ver: SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35825904973072 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
06-29-2013, 12:30 | #3 (permalink) |
Registered User Join Date: Jan 2012 Location: Above the earth
Member: 1711578 Status: Offline Sonork: 100.1606127 Thanks Meter: 51 | Observe your phone for an hour,if it not rebooting then your phone is ok.most of the time mxkey says that your unit is sd key invalid even if it not.try other box for you to know my point. |
