12-27-2014, 05:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: TELANGANA
Member: 1175976 Status: Offline Sonork: dgr Thanks Meter: 38 | nokia 5130 contact service IMEI: 358318033115555 CONFIG KEY : 8000000000000000 PROVIDER KEY : 7300100000000000 NETWORK NAME : Entel PCS Telecomunicaciones S.A.;Chile [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open Block [2] 1:Open SIMLOCK STATE : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED SECURITY_CODE : 12345 ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... |
The Following User Says Thank You to dgr-solutions For This Useful Post: |
12-27-2014, 12:41 | #6 (permalink) |
No Life Poster Join Date: Jan 2014
Member: 2100013 Status: Offline Thanks Meter: 125 | https://www.youtube.com/watch?v=7kkCOG7ta8E There is no absolute good tool But When the problem can not be solved when We must choose another tool There are many techniques You can try to format You can erase repair You can perform hardware detection |
The Following User Says Thank You to LOKEMUNFU For This Useful Post: |
12-31-2014, 04:42 | #8 (permalink) |
Member: 1175976 Status: Offline Sonork: dgr Thanks Meter: 38 | Phone Type: RM-495 SW version: V 07.97 13-09-10 RM-495 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y !NO SIGNAL(06) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 43 LCD N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO N !NOT EXECUTED(03) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 101 BTEMP N !NOT EXECUTED(03) 119 IIC N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 56 CDSP_SLEEPCLK_FREQ N !NOT EXECUTED(03) 128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
12-31-2014, 13:01 | #11 (permalink) |
No Life Poster Join Date: Sep 2005 Location: repair shop Age: 44
Member: 181825 Status: Offline Thanks Meter: 199 | water damaged 100% power ic .keep pcb dipped in methanol or acetone full night . then clean and heat .other wise change betty then avlima ic |
