GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Nokia Base Band 5 ( BB-5 ) (https://forum.gsmhosting.com/vbb/f299/)
-   -   nokia 5220 Contact service Solution (https://forum.gsmhosting.com/vbb/f299/nokia-5220-contact-service-solution-885688/)
usman0000 12-22-2009 00:55
Remove Contact service with help of JAU
JAU Good Work
Read Phone Info
Reading...
Model Type    : Nokia 5220 XpressMusic
SW Version    : V 06.51 23-03-09 RM-411 (c) Nokia
IMEI Plain    : 35366201xxxxxxxx
ST_SIM_LOCK_TEST          : FAILED!
ST_SECURITY_TEST          : FAILED!
SUPERDONGLE DATA          : VALID!
LOCK STATUS
SIMLOCK STATUS: FAILED!
CONFIG KEY    : 0000000000000000
PROVIDER KEY  : 0000000000000000
Use sx4 auth button
Reading...
IMEI Plain    : 3536620xxxxxxxx
ST_SECURITY_TEST          : PASSED!
LOCK STATUS
create simlock rpl and write with jaf
Click Calc. PM 120 with 7 blocked unlock
24407_3536620XXXXXX_UNLOCKED__REPAIR_PM120_0.pm
Write this pm Under BB5 Write pm button
now see my log
Reading...
ST_SIM_LOCK_TEST          : PASSED!
LOCK STATUS
SIMLOCK STATUS: OK!
PROVIDER KEY  : 2440700000000000
PROVIDER      : Nokia Test Operator;Finnland
Blocks        : 7
Key Counter  : 0/3
F-Bus Counter : 0/10
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
UB took 20 to 50 Log for this Work
But JAU FREE
Dung Yaiba 12-22-2009 09:29
Use Ub or MT-box to repair
mobile_hotman 12-22-2009 10:35
Bro with which version n where to find ?
appu2009 12-22-2009 10:40
how to create sim lock rpl
usman0000 12-22-2009 11:53
when u open JAU software
You will see SIMLOCK RPL BUtton there
prince_arsalan 12-22-2009 12:22
You Will Find J.A.U Here:::::
http://forum.gsmhosting.com/vbb/showthread.php?t=781730
[email protected] 12-22-2009 16:00
this JAU version plz..........
oOXTCOo 12-22-2009 16:56
simlock rpl is since version 2.7.7 implemented.
here are the newsest v2.8.0
this is the installer (thanks to ********):
www.entsperren.net/JAU/JAU_Setup.exe
from this version on, you just need to press the "download" button for new update, and all is done full automatically...
so when i release next v2.8.1 version, you just need to press a button... ;)
br.
hari
btw. in step of press "create pm120" button...
dont change to bb5 tab, just press the "Write PM" button on main tab!
this is the special button to upload fresh created pm120 direct to phone witouth need
to select any file...
its more easy and more faster...
bluffmaster 12-23-2009 12:15
JAU Good Work
Read Phone Info
Reading...
LOCK STATUS
Use sx4 auth button
Reading...
LOCK STATUS
now see my log
Reading...
LOCK STATUS
SIMLOCK STATUS: OK!
Blocks        : 7
Key Counter  : 0/3
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
But JAU FREE
Dear Friend,
Above Self Test Show...SUPER DONGLE DATA IS VALID
SO MOSTLY PHONE IN THE MARKET HAVE DAMAGED SUPER DONGLE KEY.
YOU CAN NOT REPAIR SUPER DONGLE KEY VIA J.A.U
Rgds
bluffmaster
oOXTCOo 12-23-2009 16:00
Originally Posted by bluffmaster (Post 5173761)
Dear Friend,
Rgds
bluffmaster
for superdongle key data i have a idea too, i need to test if it works after x-mas. :)
JAVA Good 12-28-2009 23:28
verry good mister hari, but what is x-mas, I see it on many thread ?
and if you have a solution for SD, it's verry good, because have some phone for testing the solution give on pm.
@usman0000
the hash of your phone a 9DDB, and can get me the product code of your phone under the battery pls, I have one work good, maybe tomorow I play with it,
Best Regards,
JAVA Good.
oOXTCOo 12-29-2009 00:01
@usman0000
Best Regards,
JAVA Good.
x-mas is christmas :)
in german: weihnachten :D
about your sd phones.
contact me per email, maybe we can try something.
JAVA Good 12-29-2009 00:41
realy, why you reply now, I think I go now to my shop, but for open the door now all neighbor call the police because think I'am a thief :mad:,
tomorow is verry far, haaaaaaaa,
Best Regards,
JAVA Good.
oOXTCOo 12-29-2009 00:58
Best Regards,
JAVA Good.
dont expect to mutch, i have nothing tested for now...
JAVA Good 12-29-2009 01:13
I know, all it's just testing, I think if you realy know all and many information in the verry small time, the best way for you is create a server and and collect some money on SL2 and new hash and why not not SL3, not reply again to a crazy unlocker like me :(
tks for all, see you tomorow, now need some sleep,
Best Regards,
JAVA Good.
Page generated in 0.25756 seconds with 6 queries
