Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 09-04-2009, 23:10   #1 (permalink)
Member: 474339
Thanks Meter: 39
Nokia 5220 dead after flash. white screen
hi cyclone team plz help me to alive 5220.
i tried to flash with fbus.not booted.then tried on usb..here is the log.
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7880
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.06, (Aug 8 2009 17:54:19, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: Revised
Box Serial Number: C0001911
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19
Initializing security card...
Card Serial Number: D30003F1
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5,04v PASSED
MCU Voltage 3,30v PASSED
Core Voltage 1,78v PASSED
VBAT Voltage 0,01v PASSED
VBAT Voltage 5,01v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 5,04v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Found 2 products, Filtering BB5 Products - wait...
1 Products left after filtering. Ready.
Retrieving Variants for Product RM-411 - wait...
448 Variants Retrieved
Booting RAP...
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Failed to Create RPL from phone -> Phone not detected
RPL backup thread finished, continuing...
Backing up simlock...
Simlock backup problem -> Phone not detected
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm411__06.51.mcusw (CMT)...
Booting RAP...
Processing Flash Image Failed -> RAP Not Responding
Failed to Process all Image files -> Failed to process rm411__06.51.mcusw
Read RPL operation not possible for USB bus
[BB5 NMWCD]: Found 0 active devices
[BB5 NMWCD]: Not Found!
Selecting USB Flashing Method...
[BB5 ADL Server]: Found 0 active devices
[BB5 ADL Server]: Not Found!
Proceeding with Dead USB Mode
Press power-on shortly to run USB Boot ROM
[BB5 BootRom]: Found 1 active devices
[Nokia USB Flashing Generic]: Opening Connection
[Nokia USB Flashing Generic]: Port opened OK!
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 0960000889C57C564794CA1A8EA99DDABCA4D016
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_ROM_ID: 273F6D55DFAAF68F
DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5
Sending RAW Loader...
Sending CMT UPDAPP Certificate and Data...
Waiting for ADL Server Startup...
[BB5 ADL Server]: Found 1 active devices
[Nokia BB5 ADL Loader USB Generic]: Opening Connection
[Nokia BB5 ADL Loader USB Generic]: Port opened OK!
ADL Server Startup Confirmed OK!
rm411__06.51.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR
EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR
Erase taken 109.765s
Writing all blocks...
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 81.125s
Processing rm411__06.51.ppm_md (CMT)...
rm411__06.51.ppm_md, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR
Erase taken 38.438s
All blocks written OK! Time taken 21.797s
Processing rm411__06.51.image_md_grey (CMT)...
rm411__06.51.image_md_grey, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Started flash erase
EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR
EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR
Erase taken 98.890s
All blocks written OK! Time taken 30.484s
Restarting CMT...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
Failed to read info -> Phone not detected
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
everthing goes fine but at the end ..fone doesnt boot in test mode..
plz help
Old 10-04-2009, 07:40   #2 (permalink)
Member: 1012165
Thanks Meter: 116
use latest version v7.23 if not okey write back up pm i guess will be okey
Nokia 5220 dead after failed flash Ralcala Universalbox 1 08-29-2009 17:39
nokia 6300 china after flash white screen sjni Infinity-Box 1 07-05-2009 20:31
Page generated in 0.23021 seconds with 9 queries
