-   Nokia Base Band 5 ( BB-5 ) (http://forum.gsmhosting.com/vbb/f299/)
-   -   nokia 5310b unlock but....... (http://forum.gsmhosting.com/vbb/f299/nokia-5310b-unlock-but-1217176/)
dxlomania 03-01-2011 03:30
expert in unlocking pls help...i use to unlock it but there is no signal on it..
are there units that after unlock no signals?:confused:
Pramod (F C) 03-01-2011 05:49
Backup RPL and full flash with latest version and write full pm without sm lock value then check ur problem solved if not solved then this problem also occured due to the frequency check and make sure u r using same kind of sim that requred
If phone is 850mhz then 900mhz or more not support
Do not forget to say thanks.............................
nirob 03-01-2011 06:06
If you are using 900 to 1800 MHz band sim, you need to convert your 5310b to 5310.
Here is the solution..
1. Backup Phone your RPL
2. Write Simlock RPL with JAF
3. write 5310 full pm without 120 and 308
i think your problem will solved..
ayaz ali 03-01-2011 06:14
1 Attachment(s)
just write this rpl 100%ok
nirob 03-01-2011 06:19
Here you will found rpl and instruction pic:
http://forum.gsmhosting.com/vbb/f550...olved-1122875/
CONCORDIA GSM 03-01-2011 06:30
Dont post which you dont know.
This can be solve using a bandconvert RPL simply.;)
CONCORDIA GSM 03-01-2011 06:31
Now you got the real solution ;)
dxlomania 03-01-2011 08:33
@ ayaz ali
you got it sir....
@all
t.y!
regards;dxl
Page generated in 0.17047 seconds with 5 queries
