Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 03-01-2011, 02:30   #1 (permalink)
Member: 1504883
nokia 5310b unlock but.......
expert in unlocking pls help...i use to unlock it but there is no signal on it..
are there units that after unlock no signals?
Old 03-01-2011, 04:49   #2 (permalink)
Pramod (F C)'s Avatar
Member: 1356436
Thanks Meter: 269
Backup RPL and full flash with latest version and write full pm without sm lock value then check ur problem solved if not solved then this problem also occured due to the frequency check and make sure u r using same kind of sim that requred
If phone is 850mhz then 900mhz or more not support
Do not forget to say thanks.............................
The Following 2 Users Say Thank You to Pramod (F C) For This Useful Post:
Old 03-01-2011, 05:06   #3 (permalink)
Member: 331853
Thanks Meter: 8
If you are using 900 to 1800 MHz band sim, you need to convert your 5310b to 5310.
Here is the solution..
1. Backup Phone your RPL
2. Write Simlock RPL with JAF
3. write 5310 full pm without 120 and 308
i think your problem will solved..
The Following User Says Thank You to nirob For This Useful Post:
Old 03-01-2011, 05:14   #4 (permalink)
Member: 294245
Sonork: 100.1602405
Thanks Meter: 103
just write this rpl 100%ok
File Type: rar 5310BandChange.rar (632 Bytes, 194 views)
The Following User Says Thank You to ayaz ali For This Useful Post:
Old 03-01-2011, 05:19   #5 (permalink)
Member: 331853
Thanks Meter: 8
Arrow
Here you will found rpl and instruction pic:
how to convert nokia 5310b to 5310. (SOLVED)
Old 03-01-2011, 05:30   #6 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 810
Dont post which you dont know.
This can be solve using a bandconvert RPL simply.
Old 03-01-2011, 05:31   #7 (permalink)
Member: 209722
Thanks Meter: 810
Now you got the real solution
The Following 2 Users Say Thank You to CONCORDIA GSM For This Useful Post:
Old 03-01-2011, 07:33   #8 (permalink)
Member: 1504883
@ ayaz ali
you got it sir....
@all
t.y!
regards;dxl
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.31190 seconds with 9 queries
