08-11-2009, 06:55 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Santiago de Cuba, CUBA
Member: 836938 Status: Offline Thanks Meter: 18 | Nokia 6234 after flashing show Phone Restricted? Help After Flashing MCU, PPM and CNT the telephone shows Phone Restricted. The codes of security not reset to the values by defect: 12345. What should I do? Help MCU SW : V 05.10 21-12-06 RM-123 (c) Nokia PPM SW : V 05.10 21-12-06 RM123_145_- (c) Nokia CVF Prd.Code: 0539254 Bpr.Code: 0525641 Prod.Sn : 2GK779625 HW Vers : 1017 EM RETU : 32 EM TAHVO: 53 RFIC Ver: 17211721 DSP Vers: pb05wk46v46 LCD Type: SEIKO IMEI : 358643-01-054052-9 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : 214-01-00000000000 SL Prof : 8000000000000000 SL Count: 00 00 BLK1= L1: CLOS Provider: Vodafone / Airtel Movil;Spain ************************************************** ********************************** Detected: V 05.10 21-12-06 RM-123 (c) Nokia 1ST BOOT : C0,07 [Rm-123] [2.0.8.5] RAPx ID : 000000010000022600010006010C192101003000 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 24E0011652E16750D702AF4B1163E193CBB5A161 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC2208-00000121, Sam K8F5615ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 2F36DDC4990FD844712A61A80C033211BD9602E3 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm123_145_30005.100.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0000FFFF CMT NOR Erase Area: 0x00010000-0007FFFF CMT NOR Erase Area: 0x000A0000-0021FFFF CMT NOR Erase Area: 0x00220000-011DDFFF CMT NOR Erase Area: 0x011DE000-011DEFFF CMT NOR Erase Area: 0x011DF000-011DFFFF CMT FLASH ERASE OK, Time: 00:45 Written: 10 Certificate(s) CMT FLASH WRITE OK, Time: 01:39 1ST BOOT : C0,07 [Rm-123] [2.0.8.5] RAPx ID : 000000010000022600010006010C192101003000 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 24E0011652E16750D702AF4B1163E193CBB5A161 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC2208-00000121, Sam K8F5615ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 2F36DDC4990FD844712A61A80C033211BD9602E3 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK Chip SECTOR_SIZE: 128k Warning, Must be Used 128Kb Sector_Size CNT File 128K Image Saved as: rm123_145_30005.10.image_cvf_128 IMAGE : rm123_145_30005.10.image_cvf_128 CMT NOR Erase Area: 0x016E0000-01E7FFFF CMT NOR Erase Area: 0x01E80000-01FDFFFF CNT FLASH ERASE OK, Time: 00:24 CNT FLASH WRITE OK, Time: 00:10 1ST BOOT : C0,07 [Rm-123] [2.0.8.5] RAPx ID : 000000010000022600010006010C192101003000 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 24E0011652E16750D702AF4B1163E193CBB5A161 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC2208-00000121, Sam K8F5615ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 2F36DDC4990FD844712A61A80C033211BD9602E3 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm123_145_3005.10.ppm_cvf CMT NOR Erase Area: 0x011E0000-016DFFFF PPM FLASH ERASE OK, Time: 00:11 PPM FLASH WRITE OK, Time: 00:25 Flashing Completed, Rebooting Mobile UI Defaults Ok, Time: 00:26 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:00 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 All Done, Time: 04:44 |
08-11-2009, 06:57 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | It looks phone is locked.Just unlock it than this problem will be fixed. |
The Following User Says Thank You to ashraf_bcs For This Useful Post: |
08-11-2009, 12:47 | #6 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
DDTCxBB5 Tools HWK SarasSoft 2.0.8.5 is NOT supported for UNLOCK u can use ufs-3 box with zulea unlocker to unlock this set DOWNLOAD zulea unlocker & use with ufs-3 device .................................................. ........ procedure for unlock open zulea 2.01 SLECT Model SL-1 (6234 IS SL-1) MAKE BAKEUP THEN PRESS BUTTON UNLOCK ur set will be unlock | |
The Following User Says Thank You to cel_phon For This Useful Post: |
Nokia 3300 after flash shows insert sim card and then contact service please help | prakashmanwar | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 11-10-2009 17:11 |
nokia 6500s after flash show only nokia | ravi mobile | Nokia Base Band 5 ( BB-5 ) | 13 | 10-30-2009 20:34 |
Nokia 3300 after flash shows insert sim card and then contact service please help | prakashmanwar | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 03-08-2009 14:57 |
6270 after flash is phone restricted | begginer | MT-BOX | 2 | 01-30-2007 20:04 |
