Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 10-15-2006, 11:29   #1 (permalink)
Member: 371094
Unhappy nokia 6280 dead flash problem...
hi everyone,
I have a n6280, I tried flashing it today fro 3.81 to 5.92. I've installed carefully the diego, phx 156, and all that was needed. I expected that my fone would die in the first try coz thatz what everybody says... but now i cant revive it.... during "verifying comm" after it reaches 50, it fails and the message says
"product flashing failer : 0x8401225A(-2080300454)- Flash: Adl Loader does not start. This may happen if USB has not yet configured, in this case wait USB to configure and restart operation. In X products this means that wrong dcm dll is used."
please help me asap,, thnx!
Old 10-15-2006, 11:35   #2 (permalink)
Member: 371094
also wanna add that ive tried repeating the process over and over again wit the same result... im lostttttttttttttttttttttt....
Old 10-17-2006, 17:00   #3 (permalink)
Member: 371094
Thumbs down syeeeeeeettt
wel i guez im f*cked.nobody botherz to help..
wel thnx for nothin guyz...........
Old 10-22-2006, 01:34   #4 (permalink)
Member: 374157
i have the same prob.. no one got solution
Old 10-22-2006, 13:12   #5 (permalink)
Member: 214581
By the sounds of it you've not done Dead Phone Flashing. Follow these instructions.
1) Goto File -> Manage Connections. Make NO CONNECTION the top priority, click it, apply, then close.
2) File -> Open Product. Select you're phone model. 6280/6288 is RM-78.
3) Flash -> Firmware Flash
4) Select the Firmware File that you need. Click Dead Phone Flashing box, then click Flash or Start or whatever the button is, I cant remember.
5) Phoenix will then say "Testing Communications 1 of 40. Press power button" or something. When this happens, press the power button on the phone. Flashing will start once the dumper is put on the phone.
It may take a few tries to get it working using dead phone flashing, you may get an error that says "Unable to get error message" or something. If that happens, just try a different 5.91 package.
Cheers!
EDIT: I should add that after Dead Phone Flashing is complete, you may get an error that says Verification Failed and the phone screen says Test Mode on it. DONT WORRY! The flashing is actually complete! Take out the phone battery and put it back in, and turn the phone on. It'll work
Old 10-22-2006, 15:11   #6 (permalink)
Member: 375753
I had problems reviving my 6280 with a dead flash just a few hours ago. In the end I reinstalled Diego+Phoenix 2006 on a completely different PC to the one I did the initial flash on and it worked fine.
If you're not getting the "press power on phone" message in Phoenix it sounds like you're not doing it properly. Follow dymsim's instructions and you should be good.
Old 10-23-2006, 23:51   #7 (permalink)
Member: 73434
Thanks Meter: 2
im in the same situation (
but when ya say
which package worked for u ??
cheers !! Mick ....
Old 10-24-2006, 02:08   #8 (permalink)
Member: 44950
Thanks Meter: 10
i try usb flashing with dead 6280 at phoenix and result with error....i dont have available fbus cable at that time. so i try the dku2 in JAF and its works...phone is revived...
Old 10-24-2006, 02:08   #9 (permalink)
Member: 73434
Thanks Meter: 2
well ive been trying and trying but with no sucess, it finds the phone, but EVERY time i get the
and so it does'nt flash ! any1 got any suggestions ??
i presume JAF is hardware and not software ??
Mick ..
Old 10-24-2006, 19:56   #10 (permalink)
Member: 73434
Thanks Meter: 2
well now its the next day, (an not 3am) i see why im having probs ! ..
its a 6680 not a 6280 !!!
soooo my next Q ! .. how can i dead phone flash a 6680 ???
cheers for ANY help Mick ...
Nokia 6280 PPM Flashing Problem Preco HWK 12 08-02-2009 13:49
Nokia 6280 dead - flash 3.40 to 6.10 and not boot now ROREM Nokia Base Band 5 ( BB-5 ) 1 09-08-2008 15:54
nokia 6280 dead flashing cuezick Nokia Base Band 5 ( BB-5 ) 3 04-25-2007 18:50
Page generated in 0.33673 seconds with 8 queries
