04-24-2007, 08:17 | #1 (permalink) |
Junior Member Join Date: Dec 2006
Member: 414815 Status: Offline Thanks Meter: 0 | nokia 6280 dead flashing Cmt->Normal USB drivers unloaded. Creating RAW connection Cmt->Connection opened successfully Cmt->Bootcode started, continue flashing... Cmt->Config data received from boot code succesfully Cmt->File is not valid ULO file (First byte is wrong) Cmt->Failed to send ULO 0x84012279 The flashing failed. Do you like to retry the flashing? HRESULT 0x84012279 (-2080300423) Flash: Tried to load empty data to phone. Check that flash images contain correct data. If you tried dead phone flashing this means that flash image does not support that. can anyone please help me tnx |
04-25-2007, 14:31 | #3 (permalink) |
No Life Poster Join Date: Jul 2006 Location: ..::DZ-25::..
Member: 315181 Status: Offline Sonork: 100.1593455 Thanks Meter: 301 | try to flash it with phoenix 2006 cracked, I have falshed many deads 6280 and they work fine just one pbm, if the securiy area is damaged the phone will be locked !! in this case I think that only the F1 box can repair it :-) good luck |
Nokia 6280 dead - flash 3.40 to 6.10 and not boot now | ROREM | Nokia Base Band 5 ( BB-5 ) | 1 | 09-08-2008 15:54 |
Nokia 6280 dead during flashing using usb | mtb116 | Universalbox | 2 | 08-08-2007 05:00 |
nokia 6280 dead flash problem... | al6280 | Nokia Base Band 5 ( BB-5 ) | 9 | 10-24-2006 19:56 |
Nokia 6280 dead after flash to 5.92 | beermat999 | Nokia Base Band 5 ( BB-5 ) | 5 | 10-16-2006 00:31 |
