03-25-2009, 00:31 | #1 (permalink) |
Junior Member Join Date: Mar 2009
Member: 996096 Status: Offline Sonork: soundcraft Thanks Meter: 1 | NOKIA 6288 camera problem When I'm trying to take a photo I must wait aprox 30 sec , sometimes more, in order to save the photo.In all this time the phone is "frozen" . And sometimes give's an error "unable to open file". If I try the "flash on" the phone starts to act like an 'stroboscope'. But "curiously" the video capture is working perfect.even at max resolution and hi quality settings. Only from time to time i can take a normal photo(5% of cases). In order to solve this problem , I flashed the phone with the same version of firmware v.6.43(at an serviece). But NO results!! I changed the memory card. NO results!! Any ideea?? Pls help!! Thanks |
03-25-2009, 20:49 | #2 (permalink) |
Member: 996096 Status: Offline Sonork: soundcraft Thanks Meter: 1 | Today I went to a service and replaced the module located right beneath the sliding keypad (keyboard) . Searching this forum I found out that this component is responsible for most malfunctioning 6288/6280 cameras.Is that right?? I also tried another screen. And all this did NOT solved my problem!! Tomorrow i'll try to change the flexible magistral(conductor). If this doesn't work , I'm OUT OF SOLUTIONS!!! So please help me with some advices!! Thanks! |
03-25-2009, 21:40 | #3 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 339455 Status: Offline Sonork: 100.1589401 Thanks Meter: 86 | Hello Under upper side keyboard(small keyboard) a video accelarator is located. In case of its failur ,the phone isnt able to work with cam and video file playback. Your phone's issue is same as mass memory problem(internal user area memory or flash memory(card)),and you sayed that you changed memory and flashed the phone and hasn't any result. check flex(cable) |
03-26-2009, 00:31 | #4 (permalink) |
Freak Poster Join Date: May 2008
Member: 764493 Status: Offline Thanks Meter: 25 | i had this problem too. i couldnt fix it i tried reflashing, replacing flex cable and camera. but every phone is different problem, some ppl got it working by just replacing ribbon cable. |
03-27-2009, 17:09 | #6 (permalink) |
Member: 996096 Status: Offline Sonork: soundcraft Thanks Meter: 1 | Hello, Finlay my problem is solved!! It looks like the flex cable was the problem.(A little bit hard to believe but thats how it is). So tanks again for the advices. |
The Following User Says Thank You to soundcraft For This Useful Post: |
Nokia 6288 - a problem with a camera | copymaker | Nokia Base Band 5 ( BB-5 ) | 9 | 02-02-2013 09:36 |
Nokia 6288 keypad problem | rors | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 09-04-2010 14:33 |
6288 camera problem | billa2008 | Nokia Hardware & Hardware Repair | 1 | 12-12-2009 10:29 |
6288 camera problem | micro_hsr | Nokia Hardware & Hardware Repair | 3 | 11-28-2008 07:30 |
6288 camera problem | leomaxuk | Nokia Hardware & Hardware Repair | 1 | 09-05-2007 14:44 |
