03-03-2009, 12:21 | #16 (permalink) | |
No Life Poster Join Date: Nov 2007
Member: 627228 Status: Offline Sonork: 100.1577983 Thanks Meter: 155 | Quote:
Here is the log is PM Problem(software) is not CPU(Hardware) no need to up the CPU geast to write PM with SX4AUTH and all will be ok is wery easy. Field: 309, Record: 0, Len: 4 -> Error: Need SX4 auth.. Field: 309, Record: 1, Len: 2 -> Error: Need SX4 auth.. Field: 309, Record: 2, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 4, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 5, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 7, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 8, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 17, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 22, Len: 12 -> Error: Need SX4 auth.. BR,vali23_mm | |
03-04-2009, 18:43 | #17 (permalink) |
Junior Member Join Date: Mar 2009
Member: 986582 Status: Offline Thanks Meter: 1 | No need to reflash!!! JUST RESTORE THE SETTINGS from a backup you did before the flash. This will take care of all the CONTACT SERVICE PROVIDER problems. In the 6301 WiFI is for UMA ONLY!! You can not connect to wifi without UMA. The phone is perfectly fine, the problem is with the user.. |
The Following User Says Thank You to noname_007 For This Useful Post: |
03-04-2009, 21:44 | #19 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | You just need to write rpl backup made by JAF when you first flashed the phone, after that your problem will be solved, rpl backup is saved with phone's imei number in name and some date.rpl in ProgData folder of JAF. Can you post here that rpl, i need one rpl from a 6301 to see if can unlock bands to a 6301b, thanks |
03-04-2009, 23:42 | #20 (permalink) |
Member: 627228 Status: Offline Sonork: 100.1577983 Thanks Meter: 155 | This is PM Problem not RPL The Problem in your Phone is "contact your service provider " this i becouse your PM is not Good You can solve this just write PM with SX4AUTH So have you Wited PM with SX4AUTH? Just write PM with SX4AUTH and Post resulet Field: 1, Record: 0, Len: 114 -> Error: Need SX4 auth.. Field: 1, Record: 2, Len: 98 -> Error: Need SX4 auth.. Field: 1, Record: 4, Len: 110 -> Error: Need SX4 auth.. Field: 1, Record: 6, Len: 98 -> Error: Need SX4 auth.. Field: 1, Record: 8, Len: 110 -> Error: Need SX4 auth.. Field: 1, Record: 13, Len: 98 -> Error: Need SX4 auth.. Field: 1, Record: 16, Len: 86 -> Error: Need SX4 auth.. Field: 1, Record: 18, Len: 86 -> Error: Need SX4 auth.. Field: 1, Record: 20, Len: 86 -> Error: Need SX4 auth.. Field: 1, Record: 25, Len: 4 -> Error: Need SX4 auth.. Field: 1, Record: 29, Len: 6 -> Error: Need SX4 auth.. Field: 1, Record: 34, Len: 80 -> Error: Need SX4 auth.. Field: 309, Record: 0, Len: 4 -> Error: Need SX4 auth.. Field: 309, Record: 1, Len: 2 -> Error: Need SX4 auth.. Field: 309, Record: 2, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 4, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 5, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 7, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 8, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 17, Len: 12 -> Error: Need SX4 auth.. Field: 309, Record: 22, Len: 12 -> Error: Need SX4 auth.. BR,vali23_mm |
03-05-2009, 01:02 | #21 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | For your info i had the same trouble, flashed 6300b to 6301b phone, after flash it back to 6301 phone displayed contact service, i wrote rpl backup made by JAF back to phone and everything went fine, luck |
03-05-2009, 02:01 | #23 (permalink) |
Member: 986582 Status: Offline Thanks Meter: 1 | I've had this issue before and I know it can be fixed by restoring a configuration that was backed up before the flash. If this is the Eu version of the phone, once restored you can go in to eh Wifi Call settings and select config and account to be used for WiFi calls. |
05-24-2009, 11:00 | #24 (permalink) | |
Insane Poster Join Date: May 2004 Age: 40
Member: 65453 Status: Offline Thanks Meter: 2 | 6301 Quote:
I also have the Contact Service problem I erased the phone + full PM + RPL that I bouhgt. still contact service.... here is the log.: Switching to serial... Powering the phone... Reading... MCU SW version: V 09.40 06-11-08 RM-322 (c) Nokia HW version: 1500 PCI version: RFIC version: 17211721 DSP version: ICPR71_08w30 LCD version: SEIKO PPM version: V 09.40 06-11-08 RM-322 (c) Nokia A BT MCM version: 2222-143 Retu version: 32 Tahvo version: 53 Content Pack version: Content: a V 09.40 06-11-08 RM-322 (c) Nokia Production serial number: KDQ501377 Product code: 0557512 Module code: 0203491 Basic production code: 0549193 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 358983011161432 IMEI spare to net: 3A 85 89 03 11 61 41 03 IMEI SV to net: 33 85 89 03 11 61 41 53 F8 LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2080100000000000 Provider: Orange + France Telecom Itineris;France Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 20801F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-322.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0557512 Searching for JAF saved location of ini... Checking path: D:\tmp\Nokia\Phoenix\Products\RM-322\ Searching for default location of ini... Checking path: D:\tmp\Nokia\Phoenix\Products\Products\RM-322\ Searching for JAF saved location of ini... Checking path: D:\tmp\Nokia\Phoenix\Products\RM-322\ Scanning ini files... Searching for default location of ini... Checking path: D:\tmp\Nokia\Phoenix\Products\Products\RM-322\ Checking path: D:\tmp\Nokia\Phoenix\Products\RM-322\ FILES SET FOR FLASHING: MCU Flash file: D:\tmp\Nokia\Phoenix\Products\RM-322\rm322__09.40.mcusw PPM Flash file: D:\tmp\Nokia\Phoenix\Products\RM-322\rm322__09.40.ppm_a CNT Flash file: D:\tmp\Nokia\Phoenix\Products\RM-322\rm322__09.40.image_a APE Variant file: NONE Languages in ppm: English,German,Finish,Swedish,Danish,Norwegian,Ice landic Done! Last edited by Zoosman; 05-24-2009 at 11:09. Reason: attachment | |
URGENT!!! - Phone blocked please contact your service provider | florinfr80 | TSMbox+ | 7 | 08-30-2013 03:37 |
nokia 6301 contact service problem | deecee | Universalbox | 5 | 12-22-2009 12:18 |
nokia 6301 contact service problem | deecee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-21-2009 21:55 |
nokia 6301 contact service | deecee | MT-BOX | 0 | 12-21-2009 16:41 |
need nokia 6301 contacte service me | gsm2share | Nokia Base Band 5 ( BB-5 ) | 1 | 01-25-2008 03:53 |
