Nokia 6500s Contact service Hi I have problem with one nokia 6500s Contact service after write pm, i try all things write backup pm + crt, erase then restore and sx4+ pmwithout 308.... i try all things without reslut plz help, here attached phone log: Switching to serial... Powering the phone... Reading... MCU SW version: V 09.40 10-11-08 RM-240 (c) Nokia HW version: 1000 PCI version: RFIC version: 17141715 DSP version: ICPR71_08w30 LCD version: SHARP PPM version: V 09.40 10-11-08 RM-240 (c) Nokia M1 BT MCM version: 2222-143 Retu version: 15 Tahvo version: 22 Content Pack version: Content: m1 V 09.40 10-11-08 RM-240 (c) Nokia Production serial number: CZA393290 Product code: 0543754 Module code: 0203327 Basic production code: 0543753 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 358675012160674 IMEI spare to net: 3A 85 76 05 21 61 60 07 IMEI SV to net: 33 85 76 05 21 61 60 57 F8 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 |
1st try write becup crt then write good pm i think solv ur problem..... then not solv write RPL solv ur problem good luck ........ |
CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Use ask to rpl service. Rpl is fully damage. Regards |
try wrire pm trow mt box sx4 config key 000000000000000 new rpl genrate ur set 100% ok Hariom |
to remove contact service and repair also SC Zone. B.R., kashi4gul |
GOOD PM HEAR...................................http://forum.gsmhosting.com/vbb/show...78#post4025678 |
@EMINEMGSM BB5+ phone use PM field 120 for sim lock. so if u have that field backup you must restore it. if not must buy rpl. |
Found cached code in codes.ini, sending to phone SIMLOCK NOT INITIALIZED! (empty board/no simlock record) now CS what is that problem.. griffin team |
its not Griffin Section .... delete code.ini from C/Program files/Griffen team/mt box/bb5 hash.. then try to unlock it again ... If problem still same then write pm backup ...which made during unlock. aslo see this video its may help you.. http://forum.gsmhosting.com/vbb/show...93&postcount=1 |
