Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 01-03-2009, 10:42   #1 (permalink)
EMINEMGSM's Avatar
Member: 57652
Nokia 6500s Contact service
Hi
I have problem with one nokia 6500s Contact service after write pm, i try all things write backup pm + crt, erase then restore and sx4+ pmwithout 308....
i try all things without reslut plz help, here attached phone log:
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 09.40
10-11-08
RM-240
(c) Nokia
HW version: 1000
PCI version:
RFIC version:  17141715
DSP version:
ICPR71_08w30
LCD version: SHARP
PPM version: V 09.40
10-11-08
RM-240
(c) Nokia
M1
BT MCM version: 2222-143
Retu version: 15
Tahvo version: 22
Content Pack version: Content: m1
V 09.40
10-11-08
RM-240
(c) Nokia
Production serial number: CZA393290
Product code: 0543754
Module code: 0203327
Basic production code: 0543753
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 358675012160674
IMEI spare to net: 3A 85 76 05 21 61 60 07
IMEI SV to net: 33 85 76 05 21 61 60 57 F8
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 0000000000000000
Provider: Unknown provider
Key Code count: 0, FBUS Code count: 0
Old 01-03-2009, 10:56   #2 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
1st try write becup crt then write good pm i think solv ur problem.....
then not solv write RPL solv ur problem good luck ........
Old 01-03-2009, 10:56   #3 (permalink)
UNIQUEM's Avatar
Member: 496203
Sonork: 100.1583640
Use ask to rpl service.
Rpl is fully damage.
Regards
Old 01-03-2009, 11:08   #4 (permalink)
Hariom123's Avatar
Member: 804452
try wrire pm trow mt box sx4
config key 000000000000000 new rpl genrate
ur set 100% ok
Hariom
Old 01-03-2009, 12:01   #5 (permalink)
kashi4gul's Avatar
Member: 460762
Sonork: 100.1592082
If you have both orignal backup CRT 308 and Rpl, so no problem
to remove contact service and repair also SC Zone.
B.R.,
kashi4gul
Old 01-03-2009, 12:22   #6 (permalink)
TUR@N ALAM's Avatar
Member: 705213
Sonork: 100:1601195
GOOD PM HEAR...................................http://forum.gsmhosting.com/vbb/show...78#post4025678
Old 01-03-2009, 13:59   #7 (permalink)
Super Moderator
stanner_austin's Avatar
Member: 49752
Sonork: 100.112446
@EMINEMGSM
BB5+ phone use PM field 120 for sim lock.
so if u have that field backup you must restore it.
if not must buy rpl.
Old 03-09-2009, 10:12   #8 (permalink)
shakeelajmal's Avatar
Member: 51639
Found cached code in codes.ini, sending to phone
SIMLOCK NOT INITIALIZED! (empty board/no simlock record)
now CS what is that problem.. griffin team
Old 03-09-2009, 20:29   #9 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
its not Griffin Section ....
delete code.ini from C/Program files/Griffen team/mt box/bb5 hash.. then try to unlock it again ...
If problem still same then write pm backup ...which made during unlock.
aslo see this video its may help you..
Full Video Repair CS For New BB5+
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
nokia 6303c contact service help.............. RABIULSK MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 04-09-2010 21:18
Nokia 6500s contact service can be repaired by UB? BUZZING Nokia Base Band 5 ( BB-5 ) 4 12-07-2009 02:38
nokia 6500s contact service tiger43 Nokia Base Band 5 ( BB-5 ) 11 06-02-2009 22:26
Page generated in 0.29227 seconds with 11 queries
