Nokia 6630 how to switch off 3G network?? Hello guys. Well i got problem. Nokia 6630 works only 1 day. I think that problem is whit 3G network. Batery burn fast becouse that. I whonna know how can i switch off 3G network, or if its that possible. Thx guys and GOOOD LUCK! Regz |
Yes it is possible to shut the 3G network. Go to Tools > Settings > Network > Network mode or something > And change it to GSM that will make it work on 3G mode. Rusty |
u mean that will make it work on 2g mode only..... |
In one of the first firmware version it's not possibile. If you can find it, you'll need a firmware update |
That will also prolong your battery time by half a day,maybe even a full day! Pozdrav :cool: |
if your firmware does not allow you to switch to gsm mode you can download the software named "OperatorFtdwk39v7.sis". You can find it easily on the net also directly on google. It's not illegal sw. Then install it and it will add into your main menu an icon named Test. Set your mobile in offline mode (in my 6680 it doesn't work in online mode). Enter the Test software and press left key. You will see a screen with the options "0 - dual, 1 -GSM, 2-WCDMA". Then click on Options and then Execute. You will be requested to input a string. Enter 0 to set dual mode (auto switch between GSM and 3G), 1 to set GSM, 2 to set only 3G mode (really boring!!). After clicking on OK the phone will reboot with the new settings... Enjoy. To come back on your steps and set back to dual mode you can do the same procedure or do as stated in the 2nd post To do this there's also a cracked version of Nokia Phoenix Software that works just with the usb cable of your mobile with no box. (you can also flash your phone with it..but if you are not used to be really careful with this!) bye! |
