09-09-2009, 09:03 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Chandpur U.P.West India
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | nokia 7210 white display after nokia logo i flash it with ufs, flashing is ok but ui is failed now the phone displays blank after nokia logo i have also tried with j.a.f. but problem is still the same. |
09-09-2009, 10:39 | #3 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | farsi_007, for Nokia flashing use MT-Box or J.A.F.!!!!!Now do what Shakeel_pattoki advice you and post selftest,so we can see what is wrong with the set...May be Security areas are damaged.... |
09-09-2009, 10:40 | #4 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | If you have problem with Security test failed or Simlock test failed,corrupted IMEI you may need RPL....see this link,bro http://forum.gsmhosting.com/vbb/showthread.php?t=520153 Last edited by DundyTM; 09-09-2009 at 10:49. |
09-10-2009, 10:31 | #6 (permalink) |
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | as i open pcb i saw that the cpmponen behinf battery connector are damage, can it be responcible for this situation. |
The Following User Says Thank You to farsi_007 For This Useful Post: |
03-25-2010, 06:12 | #7 (permalink) |
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | jaf with usb JAF version 1.98.62 Detected PKEY: 9000CB87 Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.1.22.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ Searching for default location of ini... Checking path: \Products\RM-436\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ Scanning ini files... Searching for default location of ini... Checking path: \Products\RM-436\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.20.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.20.ppm_mr CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.20.image_mr APE Variant file: NONE Languages in ppm: English,French,Portuguese Backing up CRT... Detected P-KEY: 9000CB87 P-key nokia module version 01.02 Init usb communication... Reading IMEI... Failed! Aborting! Failed to backup CRT... Detected P-KEY: 9000CB87 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Error reading phone init data... Backing up CRT... Detected P-KEY: 9000CB87 P-key nokia module version 01.02 Init usb communication... Reading IMEI... Failed! Aborting! Failed to backup CRT... Detected P-KEY: 9000CB87 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Error reading phone init data... Backing up CRT... Detected P-KEY: 9000CB87 P-key nokia module version 01.02 Init usb communication... Reading IMEI... Failed! Aborting! Failed to backup CRT... Detected P-KEY: 9000CB87 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Error reading phone init data... Backing up CRT... Detected P-KEY: 9000CB87 P-key nokia module version 01.02 Init usb communication... Reading IMEI... Failed! Aborting! Failed to backup CRT... Detected P-KEY: 9000CB87 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 06.02.002 Elf2flash 07.40.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step2... Patching RAW boot step3... Sending RAW Loader... ...................Loader Sent! Stage 2 starting.......................................... ...................................Loader Sent! Stage 3 starting..................Phone prepared OK! Waiting for the phone to boot... Searching for phone... Status byte: 8000 Selecting CMT flash... Result: 0000 Phone is in flash mode... CMT blocks: 2128, APE blocks: 0 Erasing cmt... Processing C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.20.mcusw... Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000 Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000 Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000 Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000 Erasing cmt zone 00140000 - 0119FFFF ... Erase result: 0000 Erasing cmt zone 011A0000 - 0133FFFF ... Erase result: 0000 Processing C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.20.ppm_mr... Erasing cmt zone 01340000 - 01BDFFFF ... Erase result: 0000 Processing C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.20.image_mr... Erasing cmt zone 01BE0000 - 01F7FFFF ... Erase result: 0000 Erasing cmt zone 01F80000 - 03FBFFFF ... Erase result: 0000 Send CMT CFG... Writing cmt... Processing C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.20.mcusw... Sending CMT HASH for NOLO Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... cmt->PAPUB keys already sent... Sending CMT HASH for UPDAPP Sending CMT HASH for DSP0 Sending CMT HASH for MCUSW Processing C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.20.ppm_mr... Processing C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.20.image_mr... Rebooting... Finishing CMT session... Restarting CMT... Pooling phone... Phone not found... Second try... MCUSW: (null) APESW: (null) VariantSW: (null) Prodcode: Setting test mode... Failed! Aborting! Done! |
03-25-2010, 07:10 | #8 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Lamka, Manipur, India
Member: 1241659 Status: Offline Thanks Meter: 165 | flash it with the latest version available and your problem will be solved |
The Following User Says Thank You to riders4siam For This Useful Post: |
03-25-2010, 11:51 | #9 (permalink) |
Member: 472592 Status: Offline Sonork: 100.1664052 Thanks Meter: 180 | problem Solved By Changing MCU version and Image file to the latest one Last edited by farsi_007; 03-25-2010 at 11:56. |
7210s white display | fay00 | Nokia Hardware & Hardware Repair | 5 | 03-17-2010 09:04 |
Nokia n72-5 white display after water logged | chhoton | Nokia Base Band 5 ( BB-5 ) | 1 | 09-28-2009 15:28 |
my second thread after no response help plz s520x white display after flash check log | observer123 | Infinity-Box | 2 | 09-10-2009 06:37 |
nokia 6600 white display after water clean | MisticRaider | Nokia Hardware & Hardware Repair | 11 | 07-04-2008 00:02 |
7210 no display after shock | =CostyGSM= | Nokia Hardware & Hardware Repair | 3 | 02-19-2004 02:23 |
