05-04-2012, 08:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Nepal
Member: 476676 Status: Offline Thanks Meter: 6 | nokia 7210c contact service I flashed 7210c with mxkey it all shows well but when i power on it stuck on "contact Service". can anyone help me to solve this problem? here is the log : Version from phone: 07.23 Version from file: 07.23 MXKEY [FT SCR2000 0], SN: C0811CEA Using device: HTI, FW ver: 00.50, SN: 0001311A Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35523103844260_BA CK.rpl). CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1560020503AC8A569F92C1AFF93AE0389AC9F15A ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 19.12 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0119FFFF] CMT FLASH,NOR area [011A0000-0133FFFF] erased in 1 min 36.969 s Prog.status for Asic CMT ... NOR: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: F1DCA5EA [RAP Certificate 142 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Prog.status for Asic CMT ... NOR: OK Programming completed in 1 min 24.391 s Processing PPM file: rm436__07.23.ppm_mb [BB5,BB5 ALGORITHM] size: 6.15 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01340000-01BDFFFF] erased in 34.125 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 28.391 s Processing CNT file: rm436__07.23.image_mb [BB5,BB5 ALGORITHM] page size: 128 K size: 20.27 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 35.87 MB CMT FLASH,NOR area [01BE0000-01F7FFFF] CMT FLASH,NOR area [01F80000-03FBFFFF] erased in 2 min 47.859 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 1 min 31.110 s Total time for flashing process(boot+erase+write) was 8 min 30.875 s After Flash Processing ... Reseting Factory Values OK. Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35523103844260-6 Product code: 0582775 Battery voltage: 4963 mV, current: 16 mA Language Pack: - not available. SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: 002.014 SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355231038442606 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000006 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-04-2012, 10:21 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | posted log seems ok , maybe mobile have some hardware issue !! please post here selftest result also. |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
05-06-2012, 07:02 | #3 (permalink) |
Member: 476676 Status: Offline Thanks Meter: 6 | nokia 7210c self test Desktop.rar Plz tell me the solution. |
