Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 06-12-2007, 17:12   #1 (permalink)
Member: 200653
Thanks Meter: 719
Nokia BB5 Erase
BB5 Erase ???
(MT-Box )
File Type: rar BB5Erase_8MBrap.rar (176 Bytes, 1657 views)
File Type: rar BB5Erase_16MBrap.rar (177 Bytes, 1328 views)
File Type: rar BB5Erase_EE_8MBrap.rar (179 Bytes, 1177 views)
File Type: rar BB5Erase_EE_16MBrap.rar (180 Bytes, 1220 views)
File Type: rar Erase.rar (904 Bytes, 2006 views)
The Following 20 Users Say Thank You to hs.com For This Useful Post:
Old 09-19-2007, 14:53   #2 (permalink)
Member: 109038
Thanks Meter: 2
Which version for N70 RM-84?
The Following User Says Thank You to Aiuspaktyn For This Useful Post:
Old 12-29-2007, 15:32   #3 (permalink)
glontz's Avatar
Member: 16269
Sonork: 1604924
Thanks Meter: 62
Red face
what is procedure for erase 6151 !? with jaf ?
The Following User Says Thank You to glontz For This Useful Post:
Old 12-29-2007, 19:05   #4 (permalink)
Axe Man's Avatar
Member: 221472
Thanks Meter: 8
Will those files work with HWK ?
The Following 2 Users Say Thank You to Axe Man For This Useful Post:
Old 12-29-2007, 19:37   #5 (permalink)
glontz's Avatar
Member: 16269
Sonork: 1604924
Thanks Meter: 62
Exclamation
select in mcu BB5Erase_8MBrap.bin, ...16 & ...32 and flash and erase all !!!
Old 12-30-2007, 04:57   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Yes.
Since no one team encrypt their work, all available erase file are for universal usage.
Even you can use it in phoenix.
If you confuse about flash size and addressing, you can use bb5erase unirap (posted by 911GT)
The Following User Says Thank You to gbluez For This Useful Post:
Old 12-30-2007, 09:23   #7 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Originally Posted by gbluez View Post
Yes.
Correct Its For All Universal Rap Phones Which Used In Bb5 Phones.
This File Can Use With Any Tool Which Able To Flash Phone Via Fbus.
The Following User Says Thank You to stanner_austin For This Useful Post:
Old 01-05-2008, 20:18   #8 (permalink)
Axe Man's Avatar
Member: 221472
Thanks Meter: 8
Thanks for info mates Oh and BTW which erase file can be used with each model of Nokia ? What I mean is for example with which model can I use for example this file BB5Erase_8MBrap.rar ?
The Following User Says Thank You to Axe Man For This Useful Post:
Old 01-06-2008, 10:31   #9 (permalink)
Member: 49752
Thanks Meter: 6,085
if you don't understand what we talking read my and gbluez post first then say thanks..
here is copy for you.
read this.
and forget about that size base erase files.because only 1 file can do all bb5 ..
Old 01-06-2008, 11:21   #10 (permalink)
Axe Man's Avatar
Member: 221472
Thanks Meter: 8
OK now everything is clear. I found this file and I read whole thread. There was a guy who had tried to use this file with J.A.F. Unfortunately it hadn't worked.
I have to try it with HWK. Maybe there will be the same problem.
Old 01-06-2008, 11:33   #11 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
all the uploaded files with worked with jaf also
The Following User Says Thank You to himanshu taldar For This Useful Post:
Old 05-26-2008, 12:47   #12 (permalink)
Member: 770920
Thanks Meter: 230
Sorry for renewing this thread - but I have a question which I couldn't find the answer to on this board.
Can I use UNIRAP Erase file using USB? Will I be able to flash it in DEAD-MODE over USB after that?
I believe this is what is necessary for downgrading bb5 phone, but, to be honest I would rather not brrick my phone...
I've read that in order to get your IMEI after full-erase you have to backup pm 308 field. Is that correct?
TIA
The Following User Says Thank You to amras555 For This Useful Post:
Old 05-26-2008, 13:05   #13 (permalink)
Member: 49752
Thanks Meter: 6,085
@amras555
NO YOU CAN'T.
if phone is able to detect at rom mode you can flash it.
to check it just connect usb cable to phone and press 1 time for 1 sec power on u see computer will sound it means ur phone is in dead usb boot rom mode.
I believe this is what is necessary for downgrading bb5 phone but, to be honest I would rather not brrick my phone...
no offcourse not you can downgrade to any firmware without erasing.you have to use jaf or mt box or any supported tools backup sp area (308) and imei (area flash mode rpl need fbus cable) now tick on downgrade and flash it.
no wrong again.
read bb5 faq at sticky thread.
imei is in flash and they are certificate of bb5.
to restore it u must have valid rpl backup or repair recalculated bb5 rpl.
now u have question about what is 308 then?
its sp area = sim lock area.
please check bb5 faq for more details.
hope this help you.
Old 05-26-2008, 13:16   #14 (permalink)
Member: 770920
Thanks Meter: 230
Yes now I get it. As I said sorry fo renewing this thread, but AFTER reading everything I could find I got a bit confused... I go practice n my reading shall I?
Thanks for help
Old 06-15-2008, 12:06   #15 (permalink)
Member: 384098
Thanks Meter: 33
i erase my 5300 and full flash with jaf but the phone is dead....
cmt loader was :0000FFFFFFFFFFFFFFFFFFFFFFFFFFF
does anyone can help me please? b4 i erase the phone is restricted and i flash it once b4 ,it stil can on at the moment.
i save cnt 308 backup and rpl back up before i erase the phone...but now my phone is dead..does anyone can help me?
The Following User Says Thank You to leong0723 For This Useful Post:
All Nokia BB5 New Modified PM, Bandchange RPL, Erase File, And Etc.[Solution]. delower10 Nokia Base Band 5 ( BB-5 ) 566 06-08-2018 15:41
All Nokia BB5 New Modified PM, Bandchange RPL, Erase File, And Etc.. ufsx002 Nokia Base Band 5 ( BB-5 ) 7 04-03-2010 12:10
Nokia PM,Erase BB5 Read Ask Write RPL digiphone Nokia Base Band 5 ( BB-5 ) 4 05-11-2009 16:42
Nokia BB5 Erase File Needs Rajlio Nokia Base Band 5 ( BB-5 ) 3 07-02-2008 17:09
Nokia BB5 Erase Files mohit_kripalu01 Nokia Base Band 5 ( BB-5 ) 1 01-07-2008 17:41
Page generated in 0.25815 seconds with 10 queries
