12-29-2007, 19:37 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Romania
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | select in mcu BB5Erase_8MBrap.bin, ...16 & ...32 and flash and erase all !!! |
The Following User Says Thank You to glontz For This Useful Post: |
12-30-2007, 09:23 | #7 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
This File Can Use With Any Tool Which Able To Flash Phone Via Fbus. | |
The Following User Says Thank You to stanner_austin For This Useful Post: |
01-05-2008, 20:18 | #8 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Poland
Member: 221472 Status: Offline Thanks Meter: 8 | Thanks for info mates Oh and BTW which erase file can be used with each model of Nokia ? What I mean is for example with which model can I use for example this file BB5Erase_8MBrap.rar ? |
The Following User Says Thank You to Axe Man For This Useful Post: |
01-06-2008, 10:31 | #9 (permalink) | ||
here is copy for you. Quote:
and forget about that size base erase files.because only 1 file can do all bb5 .. | ||
01-06-2008, 11:21 | #10 (permalink) |
Member: 221472 Status: Offline Thanks Meter: 8 | OK now everything is clear. I found this file and I read whole thread. There was a guy who had tried to use this file with J.A.F. Unfortunately it hadn't worked. I have to try it with HWK. Maybe there will be the same problem. |
01-06-2008, 11:33 | #11 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | all the uploaded files with worked with jaf also |
The Following User Says Thank You to himanshu taldar For This Useful Post: |
05-26-2008, 12:47 | #12 (permalink) |
Freak Poster Join Date: May 2008
Member: 770920 Status: Offline Thanks Meter: 230 | Sorry for renewing this thread - but I have a question which I couldn't find the answer to on this board. Can I use UNIRAP Erase file using USB? Will I be able to flash it in DEAD-MODE over USB after that? I believe this is what is necessary for downgrading bb5 phone, but, to be honest I would rather not brrick my phone... I've read that in order to get your IMEI after full-erase you have to backup pm 308 field. Is that correct? TIA |
The Following User Says Thank You to amras555 For This Useful Post: |
05-26-2008, 13:05 | #13 (permalink) | ||||
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @amras555 Quote:
to check it just connect usb cable to phone and press 1 time for 1 sec power on u see computer will sound it means ur phone is in dead usb boot rom mode. Quote:
read bb5 faq at sticky thread. imei is in flash and they are certificate of bb5. to restore it u must have valid rpl backup or repair recalculated bb5 rpl. now u have question about what is 308 then? its sp area = sim lock area. please check bb5 faq for more details. hope this help you. | ||||
05-26-2008, 13:16 | #14 (permalink) |
Member: 770920 Status: Offline Thanks Meter: 230 | Yes now I get it. As I said sorry fo renewing this thread, but AFTER reading everything I could find I got a bit confused... I go practice n my reading shall I? Thanks for help Last edited by amras555; 05-26-2008 at 13:22. |
06-15-2008, 12:06 | #15 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 384098 Status: Offline Thanks Meter: 33 | i erase my 5300 and full flash with jaf but the phone is dead.... cmt loader was :0000FFFFFFFFFFFFFFFFFFFFFFFFFFF does anyone can help me please? b4 i erase the phone is restricted and i flash it once b4 ,it stil can on at the moment. i save cnt 308 backup and rpl back up before i erase the phone...but now my phone is dead..does anyone can help me? |
The Following User Says Thank You to leong0723 For This Useful Post: |
All Nokia BB5 New Modified PM, Bandchange RPL, Erase File, And Etc.[Solution]. | delower10 | Nokia Base Band 5 ( BB-5 ) | 566 | 06-08-2018 15:41 |
All Nokia BB5 New Modified PM, Bandchange RPL, Erase File, And Etc.. | ufsx002 | Nokia Base Band 5 ( BB-5 ) | 7 | 04-03-2010 12:10 |
Nokia PM,Erase BB5 Read Ask Write RPL | digiphone | Nokia Base Band 5 ( BB-5 ) | 4 | 05-11-2009 16:42 |
Nokia BB5 Erase File Needs | Rajlio | Nokia Base Band 5 ( BB-5 ) | 3 | 07-02-2008 17:09 |
Nokia BB5 Erase Files | mohit_kripalu01 | Nokia Base Band 5 ( BB-5 ) | 1 | 01-07-2008 17:41 |
