03-03-2013, 05:12 | #155 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1893147 Status: Offline Thanks Meter: 0 | hi i got a nokia e50, locked to vodafone.. i think this phone is a dct4 not bb5.. will this utility still work with my phone? i tried to use few unlock codes but still cant unlock my phone.. any advise? Reading Phone Info... ===================================== Model: Nokia E50 (Business Device) Sw Ver: V 3.37.23 11-10-06 RM-170 (c) Nokia. Imei: 351892018680392 P.Code: 0541223 Life timer: 04051100 <> 000309:49 ===================================== Performing Tests... ===================================== Simlock Status: OK Security Status: OK SDD Key Status: OK ===================================== Reading Simlock Info... ===================================== VERSION: SIMLOCK SERVER VERSION 63 Provider key: 0100000000000000 Config key: 2341500000000000 Provider: Vodafone;United Kingdom Key Code Count: 3 , FBUS Code Count: 7 ===================================== Parsing Simlock Blocks... ===================================== [1,1] State: LOCKED Type: MCC+MNC Data: 23415F [2,1] State: LOCKED Type: MCC+MNC Data: 23415F Last edited by kadong; 03-03-2013 at 05:13. Reason: _ |
04-16-2013, 18:33 | #159 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1918403 Status: Offline Thanks Meter: 0 | Hello Fr3nsis, I'm having a problem similar to Sanjivus. I have a Nokia C3-00 locked to a USA carrier (ConsumerCellular). I have been given the unlock code by the carrier, but I think I entered it incorrectly too many times, so now I need to reset the counter, but Nokia BB5 USB Utility does not see my phone. I have the phone set to the Nokia OVI Suite mode, I have .Net Framework 4.0 installed. I have tried version 2.8, 2.5 and a previous version of the utility. I have even tried this on 4 different computers with the same result, "Phone not connected". I have also tried the other USB modes, Media Transfer and Mass Storage. I still get the same message, "Phone not connected". Can you offer any help with this. Thanks, RickWK |
04-16-2013, 19:37 | #160 (permalink) |
Member: 1915129 Status: Offline Thanks Meter: 1 | hi i have nokia 2690 rm635 and have some problems with the phone..how does one flash nokia and how to upgrade software..what does one require to be able to do this..my email software on phone does not let me access my email..get error..and have a certificate issue when i want to download facebook on my phone get error..i have rm635 v10.65..hope someone can help.. thanx |
04-16-2013, 19:57 | #161 (permalink) | |
Member: 1918403 Status: Offline Thanks Meter: 0 | Quote:
If it helps, my unlock code from my carrier is in this format. #pw+xxxxxxxxxxxxxxx+7# Here is the output of my attempt... Code: Reading Phone Info... ===================================== Model: C3-00 (Entry Phone) Sw Ver: V 03.65 26-01-11 RM-614 (c) Nokia Imei: xxxxxxxxxxxxxxx P.Code: 05949 Life timer: 04050400 <> 000073:10 ===================================== Performing Tests... ===================================== Simlock Status: OK Security Status: OK SDD Key Status: OK ===================================== Reading Simlock Info... ===================================== VERSION: SIMLOCK SERVER Provider key: 8000000000000000 Config key: 3104100272085625 Provider: Unknow Key Code Count: 1 , FBUS Code Count: 0 ===================================== Parsing Simlock Blocks... ===================================== [1,1] State: LOCKED Type: MCC+MNC Data: 310410 [1,2] State: LOCKED Type: GID1 Data: 2AC9 Reading PM... ===================================== Reading Field 120 ===================================== [0120,0000] , Len: 0x0050 , OK [0120,0001] , Len: 0x00A0 , OK [0120,0002] , Len: 0x0082 , OK [0120,0003] , Len: 0x0070 , OK ===================================== Reading Field 308 ===================================== [0308,0000] , Len: 0x0001 , OK [0308,0001] , Len: 0x2000 , OK [0308,0003] , Len: 0x0001 , OK [0308,0004] , Len: 0x0001 , OK [0308,0005] , Len: 0x000A , OK [0308,0006] , Len: 0x0001 , OK [0308,0007] , Len: 0x0001 , OK [0308,0008] , Len: 0x0001 , OK [0308,0009] , Len: 0x0028 , OK ===================================== File Saved on \Backup\357902040439941_16-04-2013_11.09.32.pm ===================================== Unlocking... ===================================== Sending Key Code (Old Method)...OK Code error! | |
04-16-2013, 21:57 | #162 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | in your case level is 7 but manual counter is 1 , probably 2 now, so you can insert it manualy with phone keypad if you get code error so code is wrong fbus need to check when manual counter is full ( =3 ) |
04-17-2013, 02:47 | #165 (permalink) | |
I called my carrier again this afternoon and spoke to someone with a bit more knowledge. I asked him to confirm the unlock code and then I asked him to confirm the IMEI number. It was not correct. It seems they gave me an incorrect unlock code, based on a phone and number I no longer have. He's is going to send me a new SIM chip and correct the account so I can get a proper unlock code. Thanks for a great tool. Without it I would have a useless phone. Thanks again, RickWK | |
