05-24-2012, 09:11 | #1 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia c2-01 simlock invalid any solution MXKEY Serial: [FT SCR2000 0] - C08173E1 Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.14060(05-05-2012) Processing MCU file: rm721__11.20.mcusw [BB5,XSR 1.6] size: 28.57 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: B6E2A82 CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 322002190F0C5940BFC5A3FA352AD07B8CE0B703 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: B6E2A82 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35741804024612_CE RT.rpl). CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB CMT MuxOneNAND area [00020000-000203FF] CMT MuxOneNAND area [00060000-0009FFFF] CMT MuxOneNAND area [000A0000-0025FFFF] CMT MuxOneNAND area [003E0000-005DFFFF] CMT MuxOneNAND area [005E0000-010DFFFF] CMT MuxOneNAND area [01EC0000-01EDFFFF] CMT MuxOneNAND area [027C0000-02CBFFFF] CMT MuxOneNAND area [077C0000-07B3FFFF] CMT MuxOneNAND area [010E0000-01EBFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 () sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 39.665 s Processing PPM file: rm721__11.20.ppm_meac [BB5,XSR 1.6] size: 5.80 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 8.87 MB CMT MuxOneNAND area [01EE0000-027BFFFF] Flash programming ... Programming completed in 7.882 s Processing CNT file: rm721__11.20.image_meac_059D644_007 [BB5,XSR 1.6] size: 16.46 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 75.06 MB CMT MuxOneNAND area [02CC0000-077BFFFF] Formating partition ... Flash programming ... Programming completed in 23.219 s Total time for flashing process(boot+erase+write) was 1 min 25.470 s Waiting for device boot up ... Device found: nmwcdc\Nokia C2-01 USB Phonet, PORT_ID: 17A2E554 Verifying communication to device OK. Phone Type: RM-721 (Nokia C2-01) SW Version: V 11.20 27-10-11 RM-721 (c) Nokia Imei plain: 35741804024612-9 Battery voltage: 3586 mV, current: 103 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
10-23-2013, 10:29 | #3 (permalink) |
Freak Poster Join Date: Jul 2013 Location: KARNATAKA INDIA
Member: 1982397 Status: Offline Thanks Meter: 17 | RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-721_357376046971704_23_10_13_143228_SIM.RPL" SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357376046971704 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN any splution bro argent |
The Following User Says Thank You to Quadri s.i For This Useful Post: |
10-23-2013, 14:04 | #4 (permalink) | |
Junior Member Join Date: Jul 2013 Location: Russian Federation
Member: 1982591 Status: Offline Sonork: 100.1645075 Thanks Meter: 0 | Quote:
