Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 12-17-2010, 22:19   #1 (permalink)
Member: 1022280
Thanks Meter: 14
nokia c7 new phone dead after flash mx key!!!!!!!
today dead nokia c7,after flashing mx key.....plz help meeeee
Old 12-17-2010, 22:27   #2 (permalink)
kadricom's Avatar
Member: 526292
Sonork: 100.1597116
Thanks Meter: 444
post log brother
did you use 3.4 1.6 vergen?
if yes try again the same product code in your C7 and use(rm-675 v.12.4)
Hope you sucsses
i had today 2pc no problem
http://forum.gsmhosting.com/vbb/f550...7/#post6704002
Old 12-22-2010, 18:44   #3 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
i have same probable i success flashed by same product code but steal dead
can one help us ?????????????????
Old 12-22-2010, 18:45   #4 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
PHP Code:
Library version1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
Processing MCU fileRM-675_012.004_79.92_prd.core.fpsx
[BB5,XSR 1.6]  size126.81 MB
 Supported Ids
4003192102001104400C1921020011046003192102001104600C1921020011046003192102011104600C1921020111046003192102021104600C1921020211046003192102031104600C192102031104
Make sure USB cable
Battery and charger are removed from device.
Insert USB cableBattery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Pooling for ADL device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 4A0C26D
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001030
CMT PUBLIC ID: 1DC00213E5A4034491FBD79D114B5F5518C6F471
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
 SecondaryBoot: rapuv11_2nd.fg [BB5]  version: 10.22.0 revision: 3.0 size: 0x3AC0
 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Secondary boot loaded.
FlashID0: 0000 0000  - 0000 0000 [unused/removed] type: NOR,CMT
FlashID1: 0000 0001  - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 00EC 0068  - 0000 0131 [Samsung  LH28F160BG] type: MuxOneNAND,CMT
ALG [35]: XSR 1.6
Loading CMT update server data
 Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6]  version: 10.22.0 revision: 3.0 size: 0xAC123
Update server code loaded.
Pooling for ADL device  OK.
Verifying communication to device OK.
CMT PAPUBKEYS HASH: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F
Storing certificate [NPC, CCC, HWC, R&D] ...
Partitioning....
Partitioning complete
Erase size: 489.06 MB
Flash programming ...
CMT PAPUBKEYS: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F (RAP Certificate v1 263) written.
Programming completed in 19.016 s
Processing PPM file: RM-675_012.004_13.01_MEA_A_79.92_prd.rofs2.fpsx
 [BB5,XSR 1.6]  size: 34.26 MB
Erase size: 59.25 MB
Programming completed in 5.203 s
Processing PPM file: RM-675_012.004_C04.01_MEA_1_79.92_prd.rofs3.fpsx
 [BB5,XSR 1.6]  size: 6.30 KB
Erase size: 15.00 MB
Programming completed in 0.031 s
Processing CNT file: RM-675_012.004_U06.01_79.92_prd.uda.fpsx
 [BB5,XSR 1.6]  size: 77.95 MB
Erase size: 503.50 MB
Programming completed in 13.844 s
Total time for flashing process(boot+erase+write) was 52.031 s
Timeout, no usb device found.
Flashing completed in 2 min 18.719 s
Old 12-22-2010, 18:55   #5 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
Old 12-22-2010, 19:20   #6 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
Old 12-22-2010, 19:31   #7 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
no solution ?????????????
Old 12-22-2010, 19:49   #8 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
use cyclone and feel ,happienes,,
http://forum.gsmhosting.com/vbb/f528...-fbus-1141237/
Old 12-22-2010, 19:59   #9 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
i trayed all mt box mxkey cyclone atf phoneix but same steal dead
Old 12-23-2010, 00:47   #10 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,052
Download again the flasfiles using navfirm then retry the flash
Alex
Old 12-23-2010, 09:11   #11 (permalink)
Member: 100241
Thanks Meter: 20
hi guys try to flash it usb on atf box .good luck
Old 12-23-2010, 09:16   #12 (permalink)
zohaib555's Avatar
Member: 491151
Sonork: 1601375
Thanks Meter: 54
bro flash with lateset version
Old 12-23-2010, 10:11   #13 (permalink)
UNIQUEM's Avatar
Member: 496203
Sonork: 100.1583640
Thanks Meter: 232
I have same problem with an C7 .
Sometime after flashing with MXKey it power on and goes totally dead after 24 hour.
And flashing again but not poweron with usb after flash nor going to localmode with bettry it,s ok
Regards
Old 12-23-2010, 10:58   #14 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
Mate!Try to charge log time like 5 minuts.
Old 12-24-2010, 14:06   #15 (permalink)
Member: 1022280
Thanks Meter: 14
i know that bro, i have atf box,mt box,
mx key.....ufs......this one new phone i can flash after no open!!!!
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
Page generated in 0.25898 seconds with 9 queries
