08-11-2011, 13:24 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: dil m hun
Member: 951882 Status: Offline Thanks Meter: 323 | nokia cooker NokiaCooker 1.1 Change-Log: - Fixed: support for large UDA files too (N8 - 16Gb File) but it will takes a lot of time. - Improved: NaviFirm+ plugin updated to 1.1 version. - Improved: ROFX repack seems to work properly (E71) - Improved: ROFS repack is more accurate. Supports the attExtra attribute (N8). - NOTE: You can't flash the modded N8 ROFS yet. *** Informations for Developers about Plugins *** When NokiaCooker launches your application it will pass the 4 command-line parameters below: 1) the file currently selected in the window on the right side 2) the path where the fw files have been extracted (eg: c:\nokiacooker\files\n8fw_extracted\) 3) firmware filename (eg: RM-596_011.012_U01.01_79.92_prd.uda.fpsx) 4) firmware type (UDA, ROFS, CORE, UNKNOWN) How to read the arguments depends on the programming language you're using: - for Delphi you should use ParamStr() ParamCount() - for C# you can find the source code of a skeleton Plugin inside \NokiaCooker\TestPlugins\ Description Nokia Cooker is a PC software reserved to the Cookers, which allows to modify the files containing the phone's firmware to create customized firmwares versions named Cooked-Firmware. Nokia Cooker can modify data which is located in: - UDA - ROFS - ROFx It can't modify data located in the CORE yet. Not all the ROFS/ROFx can be modded! Modding a protected ROFS/ROFx you'll risk to brick the phone. If you aren't sure that your ROFS/ROFx can be modded, don't do it. The modding of the UDA, instead, is always a safe operation. This software is provided "as is" with no warranty whatsoever, express or implied and moreover, WITHOUT any technical support, so, DO NOT contact me about this, because you WILL NOT receive any reply. If you don't know how to install, or how to use it, probably you don't need Nokia Cooker at all. |
The Following 3 Users Say Thank You to kapilpanday For This Useful Post: |
