Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-01-2012, 10:52   #1 (permalink)
Member: 1742284
Nokia E52 dead phone USB flash
Hi,
after a failed firmware update via Nokia Suite my E52 is dead now --> black display and only a short vibration after pressing the power on button. Therfore I've downloaded a current Phoenix (v2012.04.003.47798) release, a current NaviFirm Plus (v1.7) release and the current E52 firmare package (v081.003). Unfortunately there is no communication with the mobile after the firmware programming. Phoenix outputs the following log:
Flashing started
Creating product data items list
Product data items list created
Backup not required
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
Loading secondary boot code: 15168 bytes
Secondary boot loaded
BB Asic Index is: 00
Asic ID is: 000000030000022600010007600C192102011104
EM Asic ID is: 00001040
EM Asic ID is: 00001030
Public ID is: 1B800015FF5E0344584ADCC37EA7F99CA7F320A2
Asic Mode ID: 00
Hash: 25B977A055BE9B5DEC0C38A2A279C695
ROM ID: 3E273BF637BE26FA
Device type is: 05
Device Index is: 00
Manufacturer code: 0000
Device ID: 0000
Extended device ID: 0000
Revision ID: 0000
Device type is: 04
Device Index is: 00
Manufacturer code: FFFF
Device ID: 0000
Revision ID: 0000
Device type is: 00
Device Index is: 00
Manufacturer code: 0020
Device ID: 0040
Revision ID: 0031
Device type is: 00
Device Index is: 01
Device ID: 0001
Revision ID: 0000
Device type is: 03
Device Index is: 00
Device ID: 0040
Revision ID: 0031
Loading update server code: 868592 bytes
Update server loaded
Asic CMT: Start programming 172010 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Asic CMT: Programming data sent: 100%
Programming complete
Asic CMT: Verifying communication to device...
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Error 0x8401F121 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
Starting to recover the phone
Recovering phone
Initializing
Phone recovery completed. Waiting for phone to boot up
Bootup successful
Verifying communication to product (before flash finalizing)
Failed to verfy communication to product
After the 25 tries to communicate with the E52 there is a request from Phoenix to disconnect and reconnect the USB connection. This doesn't help and the whole process ends with following error message:
Flashing finalization failed. Do you like to retry the finalizing?
HRESULT 0x8421001c (-2078212068)
Firmware: Cannot verify communication to phone after flashing. Make sure that phone booted up correctly and retry.
Hope someone of you can help me out here. The battery should be OK --> it delivers roughly 3.74V so it is still the nominal voltage.
Old 04-01-2012, 12:01   #2 (permalink)
NOKIA_PLUS's Avatar
Member: 1547481
bro post this model type and product code i solve your problem
Old 04-01-2012, 12:15   #3 (permalink)
Member: 1742284
Hi,
thanks for the fast reply.
Model: E52-1 (Type: RM-469)
Code: 0591667
Old 04-02-2012, 13:28   #4 (permalink)
NOKIA_PLUS's Avatar
Member: 1547481
Bro Flash File Ver.81.3 Download and flash work 100% post result
Old 04-02-2012, 18:52   #5 (permalink)
Member: 1742284
I'm already using the 081.003 firmware package. I recharged the battery with another E52 (measured voltage is roughly 3.95V). Unfortunately I get the same result --> the flash procedure stops with an error.
Here is the procedure as I execute it:
  1. start Phoenix and choose "NO CONNECTION"
  2. File -> Open Product and choose "RM-469"
  3. Flashing -> Firmware Update
  4. choose Product Code (0591667) and tick "Dead phone USB flashing"
  5. click "Refurbish"
  6. wait until I get the request to connect the USB cable and to insert the battery (pressing the power button is not needed): the device manager lists the two devices "Nokia USB Flashing Generic" and "Nokia USB Flashing Parent"
  7. after the programming process these devices disappear
  8. after that there are 25 attempts to communicat with E52 (without success)
  9. at the end there is a request to disconnect and reconnect the USB cable (the devices mentioned above appear for roughly 4 seconds in the device manager and disappear again)
  10. the whole process is aborted with the error that no communication is possible with the E52
I also tried a second USB data cable (also a Nokia C-101 data cable). Furthermore I also used another USB port and also a WinXP x68 machine --> alsways the same result (current system is a Win7 x64). Does anybody know what else could be the reason for the error?
Old 08-02-2012, 16:48   #6 (permalink)
Member: 1792509
same problem with me ((
Old 08-02-2012, 17:09   #7 (permalink)
Member: 1626204
help me urgent bro.......
i have nokia 5230
code:0585713
last 30 days back i sucessufuly flashed with 51.9.2 version by using { ufs3-hwk }downloading in navifrim
but in info its shows the mobel is 5238.....
and now the same i s hanging now and music player is not working >that why i tried to flash again today but its not working
1 st boot ok,,,,2 nd boot ok ...the problem was CNT FLASH WRITE DATA REQ FAIL........I TRIED WITH 51.9.2
AND 50.0.1
AND 50.6.1
AND I AM USING USB CABLE TO FLASH
AND I TRIED TO F BUS CABLE BUT IN THAT 1 ST BOOT ERROR IS COMING
AND NOW THE PHONE CONDITION IS DEAD ......PLSE HELP ME ,PLSE SAVE ME
ADVANCE IN THANKS FOR HELP
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.25522 seconds with 11 queries
