12-22-2012, 02:13 | #1 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1856008 Status: Offline Thanks Meter: 0 | Nokia E55 won't startup...vibrate only ! My E55 wont start up after vibrate. I try to flash (RM-482 - SW-034.001)with latest version of phoenix but no luck After successfully flashing process with phoenix give this message: "This mobile device is not detectable after flash operation." Help me please ! |
12-22-2012, 06:45 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: bangladesh, dhaka, munshiganj. Age: 37
Member: 570626 Status: Offline Sonork: 100.1579059 Thanks Meter: 129 | write first blank ppm then full flash. WBR shimul. |
The Following User Says Thank You to shimul_777 For This Useful Post: |
12-22-2012, 19:00 | #9 (permalink) |
Member: 1856008 Status: Offline Thanks Meter: 0 | Nokia E55 hard reset key combination: Shift+Backspace+space+power. I have tried all these mothods/tricks, my phone is dead... the only thing it does vibrate on power button press. I want to know how to write blank ppm and where i can find ppm/eno files ? |
12-22-2012, 20:37 | #11 (permalink) | |
Member: 1856008 Status: Offline Thanks Meter: 0 | Quote: I have 2 question: 1- does work this file for my phone Nokia E55 ? 2- Can you explain please how to flash with phoenix or jaf step by step this blank ppm ? thank you again. | |
12-22-2012, 21:37 | #13 (permalink) |
Member: 1856008 Status: Offline Thanks Meter: 0 | Sorry for my noob questions but for you all who are experts is very easy to do and to understand. I'm not expert and and these little things that I learned thanks to the problem that I have with my phone. I'm lost.. I dont know where to put your ppm file in phoenix I open firmware update in phoenix,select product code ,tick dead phone usb flashing and open options,in options window open i see 6 files tupe: image,content,ppm,ppm,content,memcard content. Now can you explain please what should I do to flash with blank ppm file in this situation ? Thank you. |
12-23-2012, 04:26 | #15 (permalink) | ||
Member: 1856008 Status: Offline Thanks Meter: 0 | Quote: Here is the phoenix logs: Code: Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 15168 bytes Secondary boot loaded BB Asic Index is: 00 Asic ID is: 000000030000022600010007600C192102011104 BB Asic Index is: 00 EM Asic ID is: 00000C34 BB Asic Index is: 00 EM Asic ID is: 00000C30 BB Asic Index is: 00 Public ID is: 08700002FA5E0344C71E054B645B6C4B50B942FD BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: 25B977A055BE9B5DEC0C38A2A279C695 BB Asic Index is: 00 ROM ID: 3E273BF637BE26FA BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0020 Device ID: 0040 Extended device ID: 0000 Revision ID: 0031 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 03 Device Index is: 00 Manufacturer code: 0020 Device ID: 0040 Extended device ID: 0000 Revision ID: 0031 Error searching for CmtAlgorithm file from disc No CmtAlgorithm server file found for this phone ERROR: Failed to set phone to flashmode Starting to recover the phone Recovering phone Initializing Flashing phone Initializing Scanning image files... Waiting for USB device... Quote:
