Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 06-01-2008, 17:55   #1 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 262
Thumbs up nokia n70 chargeing ok but no power on
hi friends,i have nokia n70 ,charging ok,but not switch on ,
when i connect with jaf its switch on,and taking full flash without any error,
power on/off switch is ok,but there is not any voltage from retu,so i removed the retu and checked the track from retu to on/off switch,track is ok,so finally ,i replaced new retu from working phone ,but still same problem,
there is not any voltage at on /off switch,but taking charging,any on with jaf
please ,suggest me ,now what to do,
The Following 2 Users Say Thank You to san9090 For This Useful Post:
Old 06-01-2008, 18:13   #2 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,022
try this solution
http://www./showpo...1&postcount=13
The Following 2 Users Say Thank You to SHOEB AHMED For This Useful Post:
Old 06-01-2008, 18:31   #3 (permalink)
unlock & flash's Avatar
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
change only 2nd display ic.100% solved your problem
The Following 2 Users Say Thank You to unlock & flash For This Useful Post:
Old 06-01-2008, 18:41   #4 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 262
Thumbs up thanx man 4 ur reply
i will try it tommorrow ,but i a have already check the track its ok ,
Originally Posted by SHOEB AHMED View Post
Old 06-02-2008, 17:54   #5 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 262
Thumbs down thanx man its works
thanx man for your help
The Following User Says Thank You to san9090 For This Useful Post:
Old 06-05-2008, 09:16   #6 (permalink)
Member: 782918
Thanks Meter: 3
on off track going to display ic change ic then first track chek
The Following User Says Thank You to pankaj_alfa For This Useful Post:
Old 06-05-2008, 09:43   #7 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,346
chenge the LCD ic(right side)
The Following 2 Users Say Thank You to pupaji For This Useful Post:
Old 06-05-2008, 09:50   #8 (permalink)
.:KRISHNA:..:MOBILE:.'s Avatar
Member: 304012
Thanks Meter: 314
Nokia N 70+n72 power switch
The Following 3 Users Say Thank You to .:KRISHNA:..:MOBILE:. For This Useful Post:
Old 06-05-2008, 18:56   #9 (permalink)
zahed1978's Avatar
Member: 444785
Thanks Meter: 170
change 2nd display ic.100%ok
Old 06-06-2008, 12:56   #10 (permalink)
Member: 775521
hi
please con-this mo no 9860553397
Old 05-21-2011, 09:50   #11 (permalink)
Member: 1194678
Sonork: babamax
Thanks Meter: 4
Try this...........
http://imageshack.us/photo/my-images/815/n70.png/
nokia 6680 charging ok but no power on tuban_gsm Nokia Hardware & Hardware Repair 3 02-02-2010 05:18
nokia 6300 charging ok but no power on qayyoom1 Nokia Hardware & Hardware Repair 12 06-01-2008 12:03
N70 flashing ok, but no power on plobony UFS2 + UFS3-Tornadoflasher 3 08-17-2007 14:18
NOKIA 33XX-3410 Charging OK but No Power ON! <<SOLUTION>> CyberoptiK Nokia Hardware & Hardware Repair 2 11-24-2004 07:20
c55 charge ok but no power on thetunisiancrow E-Gold Based Phones 5 09-30-2004 14:53
Page generated in 0.38944 seconds with 8 queries
