03-18-2014, 08:27 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: BANGLADESH Age: 36
Member: 885431 Status: Offline Thanks Meter: 80 | nokia n9 flash problem Processing Image File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin CMT Type : MAEMO/MEEGO C:\AdvanceBox Turbo Flasher\Logs\flasher.exe -F DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin C:\Program Files\Nokia\Phoenix\Products\RM-696\ ================================================== ==== ================================================== ==== BB5 MEEGO / HARMATTAN FLASHER ================================================== ==== ================================================== ==== 1. Turn OFF Phone and wait 10 Seconds... 2. Connect the USB Cable to the PHONE Micro USB Port 3. Connect the USB Cable to the PC USB Port TIPS & INFORMATION: 1. To Turn OFF the Phone, PRESS and HOLD the POWER button for at least 10 Seconds... 2. Battery Charging will still work on "DEAD" Phones. 3. Factory Reset will make Flashing 15 minutes longer and it will Totally Erase the User Data and Remove the Phone Lock + Security Code as well... 4. Skip ADL Chk will Cold Flash the Device. ================================================== ==== ================================================== ==== Waiting For Phone on USB PORT/s... REQUIRED MODE: BOOTLOADER MODE PHONET MODE Sending APE-ALGORITHM: SUCCESSFUL Nokia Bootloader/PhoNet Found! ================================================== ==== SECURE USER DATA ERASING IN PROGRESS ================================================== ==== Secure Data Erasing takes about 15 MINUTES... DO NOT DISCONNECT THE PHONE!!! JUST WAIT... Estimated Time to Finish Erasing: 13:13:00 (24-h Time Format) ================================================== ==== Battery Voltage Test: PASSED Ready to Flash Images to Device... ========================================= Processing Image: cert-sw ERROR: MEEGO Device Flashing Failed! Firmware Version Downgrade NOT ALLOWED Please use a HIGHER Firmware Version... Booting/Flashing Failed... Please Try Again... any body can help for higher version & LINK |
03-18-2014, 08:50 | #4 (permalink) | |
Freak Poster Join Date: May 2011 Location: INDIA
Member: 1584831 Status: Offline Thanks Meter: 46 | n8 flashing problem Quote:
