Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 09-15-2009, 16:12   #1 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Nokia N97 : Format / Hard Reset On Bootup
Nokia N97 : Format / Hard Reset On BootupIts always a good idea to do a format once every few month or even when you first get your new s60 device.
theres 2 ways to do a hard format to the device memory:
1). once the device is powered on and at the home screen type *#7370# and then enter your security code (default is 12345) and then your device will restart and reset.
2-a). to hard reset when the device is off hold down the green call key, the number 3 key and the *+ key then continue to hold the keys and now hold the power key, hold all 4 keys untill the devicce boots upp and asks for the country etc.Diagram
[IMG]http://2.bp.********.com/_FKg0lveUg34/SqUnePDi-zI/AAAAAAAAAFY/4jt0L46PBMs/s400/n79frontbluelowres.jpg[/IMG]
*NOTE if you own a nokia 5800 XM then the second option is:
2-b). hold the green and red call keys, the camera capture key and then the power key, hold them untill the device boots up and asks for country etc.5800XM Diagram
[IMG]http://3.bp.********.com/_FKg0lveUg34/SqUnx5kcRJI/AAAAAAAAAFg/DmZ0VukiJSI/s400/nokia5800xpressmusic8.jpg[/IMG]
*NOTE if you own a nokia n97 then the second option is:
2-c). Hold the left shift key, the spacebar and the back key then the power key, hold them until the device asks for the country etc.N97 Diagram
[IMG]http://4.bp.********.com/_FKg0lveUg34/SqUoBWUrgnI/AAAAAAAAAFo/G_6uXeT48fc/s400/n97.png[/IMG]
If your device fails to boot up or gives a contact the retailer message then a hard format on boot will usualy sort the problem.
WARNING doing a hard reset will DELETE all user data on the device memory, including contacs, calendar entries and any apps etc you have installed to C: drive, your mass memory/memory card will remain unafected so any data will still be there, however you may have to reinstall some apps even if they are installed to mass mem/mem card.
(~(~(~My Blog~)~)~)
The Following 12 Users Say Thank You to murtaza_nns For This Useful Post:
Old 09-16-2009, 06:57   #2 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
Hi man thanks for your information,look if you can give me a hint please:
ust got a new N97 RM-505.Phone is new and ok.Problem is that user copied some bad files to internal storage,now it can't be formatted,neither format via PC is possible,PC say's disk is write protected but i don't see any option in the phone,i flashed with latest firmware,internal storage is detected ok even can copy to or from,just can't be formatted.i checked it by KIS for any viruses but nothing there,plz help.
N97 mass storage problem
The Following 3 Users Say Thank You to meisam For This Useful Post:
Old 09-16-2009, 06:57   #3 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
Old 09-16-2009, 07:52   #4 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
When you manually formated what happend?
Old 09-16-2009, 08:17   #5 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 212
I did manual format from phone menu,it said "Mass memory is in use by other application,continue anyway?" confirmed and get : "Error Occured,operation cancelled".
Now tried via pc in mass storage mode and it said "Disk is write protected" or "Media is in use by other applicaiton"
Old 09-16-2009, 14:35   #6 (permalink)
mazmaz1's Avatar
Member: 339455
Sonork: 100.1589401
Thanks Meter: 86
Hello
Mr meisam ,this may be hardware prob,
are you do it with any nokia boxes?
Old 12-15-2009, 19:38   #7 (permalink)
Member: 667941
Sonork: 100.1611812
Thanks Meter: 61
any man healp me? samsung s8003 network problem....... plz healp me................................................ .....
The Following User Says Thank You to anjuman For This Useful Post:
Old 12-16-2009, 00:05   #8 (permalink)
Member: 1184472
Thank you for the post.
May I have a question, does this reset also unlock the phone from a specific network, e.g. T-mobile?
Old 12-16-2009, 20:18   #9 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
No, this will not unlock the mobile.
Old 12-17-2009, 14:25   #10 (permalink)
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
Originally Posted by *********** View Post
not work, the N97 phone is still locked, I'd prefer to buy another unlock one, though it's fake...
Who says it will unlock the phone?
Nokia N97 : Format / Hard Reset On Bootup murtaza_nns NoooX Box 24 07-17-2012 06:49
Nokia N97 : Format / Hard Reset On Bootup mohamed73 Nokia Multimedia 7 06-06-2011 08:32
Nokia N97 : Format / Hard Reset On Bootup murtaza_nns Cyclonebox 0 09-15-2009 16:40
Nokia N97 : Format / Hard Reset On Bootup murtaza_nns Universalbox 0 09-15-2009 16:39
Page generated in 0.18557 seconds with 9 queries
