04-27-2017, 23:05 | #1 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2711198 Status: Offline Thanks Meter: 1 | How to reset Nokia 6234 code counter? I have received official code from Vodafone to unlock phone but need to reset counter to take restriction off. Have tried Counter-Reset-Usb-Nokia, BB5 USB Utility, SendCodeUsb and Nokia Best , all these programms but have no luck, can not send code via USB too or reset counter to "0" This is what I have here: ______________________ Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6234 Software ver : V 03.70 15-05-06 RM-123 (c) Nokia IMEI : 359395003239556 DSP Ver : pb05wk46v20 PPM : V 03.70 15-05-06 RM123_145_- (c) Nokia CVF CNT : Content: vg_uk_contract V 03.70 15-05-06 RM123_145_- (c) Nokia Product SN : 2GI928757 Product code : 0534825 Base Prd.code: 0525641 Module code : 0202772 Hardware info======= HWID : 1006 Retu : 32 Tahvo : 52 Batery: 3900 mV LCDVer: SEIKO Lock info =========== IMEI : 359395003239556 IMEI spNet : 3A 95 93 05 30 32 59 05 IMEI svNet : 33 95 93 05 30 32 59 05 F3 Conf key : 8000000000000000 Provider key : 2341500000000000 Country : United Kingdom Operator : vodafone UK Counters : Key 3 [3] , Fbus 7 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SL phone User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! __________________________ Any help, much appreciated!!! Thank you very much!!! |
04-27-2017, 23:36 | #3 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Europe Age: 44
Member: 126827 Status: Offline Sonork: 100.70299 Thanks Meter: 60 | Counters : Key 3 [3] , Fbus 7 [10] (3 tries remains) still F-bus 7 [10] means you can send code via cable (if you have good code) or simply do direct unlock (need F-Bus cable) |
04-28-2017, 09:04 | #4 (permalink) | |
Member: 2711198 Status: Offline Thanks Meter: 1 | Quote:
I don't have F-Bus cable and tried to send code via usb which gives me error or nothing. May be it is wrong code hmmmm? I have requested from Vodafone directly, not 3rd party resellers. Is there a way to reset counter, so I could try type in the device directly? None of the mentioned programms worked, Nokia Best 1.75 shows that CPU is not supported. Please let me know, much appreciated. x | |
04-28-2017, 09:52 | #6 (permalink) | |
Member: 2711198 Status: Offline Thanks Meter: 1 | Quote: RESET BB5+ COUNTER (SL2,SL3) - is not working for me as I have SL phone or SL1. SEND UNLOCK CODE -- gives me error , like any other USB send code app. I have tried to send code using Nokia Best, BB5 Usb Utility, Nokia BB5 USB code sender, - all exactly the same. I guess wrong code received from Vodafone. | |
04-28-2017, 23:04 | #11 (permalink) |
Member: 126827 Status: Offline Sonork: 100.70299 Thanks Meter: 60 | RPL is unique file generated by Nokia that can rebuild phone IMEI and simlock and some other security area's it cost about 20$ now days what level of code vodafone sent you? try level 1 and 7 First of all make backup good luck |
04-29-2017, 10:36 | #12 (permalink) | |
Thank you. | |
05-02-2017, 12:33 | #13 (permalink) | |
#pw+code+7# ? But I have to reset code counter? | |
05-02-2017, 12:36 | #14 (permalink) |
Member: 2711198 Status: Offline Thanks Meter: 1 | MODEL: NOKIA 6234 (SMART CLASSIC PHONE) SW: V 03.70 15-05-06 RM-123 (C) NOKIA IMEI: 359395003239556 P.CODE: 0534825 LIFE TIMER: 4C0E0000 <> 000001:01 ST_SIM_LOCK_TEST: PASSED ST_SECURITY_TEST: PASSED ST_SUPERDONGLE_TEST: PASSED VERSION: SIMLOCK SERVER VERSION 63 PROVIDER KEY: 8000000000000000 CONFIG KEY: 2341500000000000 PROVIDER: VODAFONE;UNITED KINGDOM KEY CODE COUNT: 3 , FBUS CODE COUNT: 7 BLOCK 1 [1] LOCKED: 23415F ?????? Anyone, please. How to crack this problem? Thank you all. |
