Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 01-21-2012, 06:40   #1 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
Nokia X2-01 After Flash Only Wight Then Restart Problem
First Phone Some Time Auto Off Problem ..
I Try to Flash Latest Version With ATF Box
After UI Settings Failed Only Wight Then Restart Problem
Here is Flash Log :
Number of Image Files: 3
Processing Image File :
RM-709__08.70.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 504
Entry Point: 0x01F2
Page Format : -1
MAX PAGE : 0x0000E000
RM-709__08.70.ppm_mr
CMT Type : BB5
Number of Blocks : 115
Entry Point: 0x0113
Page Format : -1
RM-709__08.70.image_mr_059C7M3
CMT Type : BB5
Number of Blocks : 514
Entry Point: 0x0147
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Flashing DOES NOT Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
Initialise*****trap_DCT5 DIR
BootFlashMode_DCT5
BootRom Verified!
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 6 (0x06)
1 SYSTEM_ASIC_ID 01
Block Length : 17 (11)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000000
ID DWORD 1 : 00000000
ID DWORD 2 : 22000509
ID DWORD 3 : 200C0000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 0000537F
3 PUBLIC_ID 12
Block Length : 21 (15)
ID DWORD 1 : 002BFB57
ID DWORD 2 : 2997F9E8
ID DWORD 3 : 5E42BB2A
ID DWORD 4 : 549813C8
4 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
5 ROOT_KEY_HASH 14
Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
6 ROM_ID 15
Block Length : 9 (09)
CRC 0 : DE56D582
CRC 1 : BDDE7A3A
START FLASHING
RawLoaderExtract: RM-709__08.70.mcusw
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_u sb2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0020 ->
Device ID : 0030 -> Type not in database
Revision ID : 0131
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0010 ->
Device ID : 0011 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Revision ID : 0131
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
SearchFor*****trap_DCT5 : No Error - 0 (0x00)
Flash Descriptor
Device ID : 0030
Revision ID : 0000
Size : 08000000 (128 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_X SR16_usbalg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
37955B6FC432998EF0DB240E332228384D19ED09
ImagePath: C:\Program Files\Nokia\Phoenix\Products\rm-709\
ImageFilename: RM-709__08.70.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00020000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02A00000
Partition 3
Start Address : 07540000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000025E0000000000080000000102A0000004B400 000000000A0000000107540000006000000000000B00000001 07B40000001800000D
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x90 (144)
ERASE Blocks : 0x03 (3)
0 ERASE_AREA_BB5 0x12
Block Length : 0x2B (43)
Device Index : 0x00
0 : 00000000-0001FFFF
1 : 00020000-000203FF
2 : 00060000-012FFFFF
3 : 01300000-01DFFFFF
4 : 02600000-029FFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B0003000002000000 0203FF120B00030000060000012FFFFF120B00030001300000 01DFFFFF120B00030002600000029FFFFF11
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
Successfully erased..
Total blocks to write : 504
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
ImageFilename: RM-709__08.70.ppm_mr
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01E00000-025FFFFF
ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E
Total blocks to write : 115
ImageFilename: RM-709__08.70.image_mr_059C7M3
StartErase_DCT5...
BlockLength : 0x3F (63)
ERASE Blocks : 0x02 (2)
Device Index : 0x00
0 : 02A00000-0753FFFF
Device Index : 0x00
Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5001120B00030002A000000753FFFFE4
FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
Total blocks to write : 514
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:15
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Elapsed Time: 5 Seconds...
Elapsed Time: 10 Seconds...
Elapsed Time: 15 Seconds...
Elapsed Time: 20 Seconds...
Elapsed Time: 25 Seconds...
Elapsed Time: 30 Seconds...
Elapsed Time: 35 Seconds...
Elapsed Time: 40 Seconds...
Elapsed Time: 45 Seconds...
Elapsed Time: 50 Seconds...
Elapsed Time: 55 Seconds...
Elapsed Time: 60 Seconds...
Elapsed Time: 65 Seconds...
Elapsed Time: 70 Seconds...
Elapsed Time: 75 Seconds...
Elapsed Time: 80 Seconds...
Elapsed Time: 85 Seconds...
Elapsed Time: 90 Seconds...
Elapsed Time: 95 Seconds...
Elapsed Time: 100 Seconds...
Elapsed Time: 105 Seconds...
Elapsed Time: 110 Seconds...
Elapsed Time: 115 Seconds...
Elapsed Time: 120 Seconds...
Elapsed Time: 125 Seconds...
Elapsed Time: 130 Seconds...
Elapsed Time: 135 Seconds...
Elapsed Time: 140 Seconds...
Elapsed Time: 145 Seconds...
Elapsed Time: 150 Seconds...
WARNING: Phone is not in the Required Mode...
Disconnect the Phone and Power it Up Manually.
Any Good Solution .......
Old 01-21-2012, 15:46   #2 (permalink)
NIYUBAHRIN's Avatar
Member: 1333065
Sonork: 100.1656291
Thanks Meter: 12
bro,
flash with new version
Old 01-22-2012, 21:41   #3 (permalink)
Member: 824971
solution for x2-01 restarting
there is 2 ic closed to the sim reader,just change them<
Old 01-24-2012, 06:21   #4 (permalink)
Arshu007's Avatar
Member: 1476028
Sonork: 100.1625985
Thanks Meter: 114
Originally Posted by NIYUBAHRIN View Post
bro,
a already Flash Latest Version (08.70)
Page generated in 0.20712 seconds with 9 queries
