07-06-2012, 00:08 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Bahrain
Member: 1739869 Status: Offline Thanks Meter: 10 | Nokia x6 SP Data Corrupted ! Help please MCU SW : V ICPR72_10w04.5 22-03-10 RM-559 (c) Nokia CNT SW : v 001_000 17-03-10 vanilla RM559 APE Core: V 20.0.005 APE Var : V 20.0.005V 20.0.005 V 20.0.005 APE ENO : rm559_ENO_A_09wk28v0.470 Product : Nokia X6-00 Prd.Code: 0589448 Bpr.Code: 0589312 Mod.Code: 0204448 Prod.Sn : CSF716360 HW Vers : 1123 APE HW : 256 APE Adsp: 256 EM VILMA: 16 EM BETTY: 22 RFIC Ver: Vapaus_5.1 | Aura_?.? DSP Ver : ICPR72_10w05 BT Id : 6C 9B 02 A7 AC 9D WLAN Id : 6C 9B 02 A7 FA BD IMEI : 353422-04-373967-0 SL Conf : 000-00-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 Bad SL Structure BC: 00 Provider: Not Found i did write pm files many times but this is not working bad sp structure... i asl tried BB5 fix me , here is the detail . Reading simlock status... Reading simlock status... OK SwVersion: V ICPR72_10w04.5 22-03-10 RM-559 (c) Nokia Imei plain: 353422043739670 LOCK STATUS: SP DATA CORRUPTED ! how do i fix this problem ? i have read all posts but i didn't find any good solution . please give a simple solution |
07-06-2012, 00:46 | #2 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hi.. if u dont have RPL or SL data backup u dont fix it.. only Factory RPL can fix it.. what was the phone pb.? what is the phone history..? |
The Following User Says Thank You to LoveLess For This Useful Post: |
07-06-2012, 07:04 | #3 (permalink) |
Member: 1739869 Status: Offline Thanks Meter: 10 | history ! Nokia X6 16GB Tmobile uk came to unlock after unlock this problem started when turn on the phone it vibrate the Nokia logo appears on it after few minutes screen blink in different colors then it goes off . i did try to check its BSI points rather then that i use USB for flash it with original flash files obtain via Flash file downloeder , Now then i did also try to write pm file many times flash it again C drive D , E but till now im having this issue , only the matter i want to resolve is (SP Data Corrupted ) i using UFS3 hwk , maybe here is someting i missing to do with this mobile so i need your opinion tested formula to fix it , thanks |
07-06-2012, 16:24 | #5 (permalink) |
Member: 1739869 Status: Offline Thanks Meter: 10 | Reading simlock status... Reading simlock status... OK SwVersion: V ICPR72_10w04.5 22-03-10 RM-559 (c) Nokia Imei plain: 353422043739670 LOCK STATUS: SP DATA CORRUPTED ! |
07-06-2012, 20:22 | #6 (permalink) | |
Registered User Join Date: Nov 2009 Location: RSA
Member: 1166923 Status: Offline Thanks Meter: 77 | Quote:
Enter this link will help you solve your problem. http://forum.gsmhosting.com/vbb/f718...6/#post8564741 Best regards | |
The Following User Says Thank You to AOA For This Useful Post: |
07-06-2012, 20:40 | #7 (permalink) |
Member: 1739869 Status: Offline Thanks Meter: 10 | guys maybe its possible if you get a mobile Nokia x6 save its rpl file with back up then to use it for unlock simlock for an other same mobile phone ? find it plz... |
