01-29-2009, 08:24 | #5 (permalink) | |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
- Connect jaf box and start the software - Select BB5 tab - Select Manual - Select "Enter Codes" Option from Unlock Setting and then Click to Unlock, when it ask you abt Enter Code simply enter your code and then click to Ok. B.R., kashi4gul | |
The Following 2 Users Say Thank You to kashi4gul For This Useful Post: |
01-29-2009, 11:13 | #6 (permalink) | |
No Life Poster Join Date: May 2003
Member: 29652 Status: Offline Thanks Meter: 43 | tks Quote:
i will try.....and post results | |
01-29-2009, 11:44 | #7 (permalink) |
Freak Poster Join Date: Oct 2007 Location: E G Y P T Age: 38
Member: 613706 Status: Offline Sonork: 12345 Thanks Meter: 13 | use jaf box to un lock ur phone with usb cable only press on (user code edite) botton on software you will see ur security code br amr |
02-04-2009, 10:56 | #9 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: Spain
Member: 595735 Status: Offline Thanks Meter: 20 | imposible Quote:
Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\356406026945138_CRT_backu p_105042.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2140700000000000 Provider: Movistar (DCT3);Spain Key Code count: 3, FBUS Code count: 7 Block 1: Lock 1: CLOSED -> Lock Data: 21407F Block 2: Lock 1: CLOSED -> Lock Data: 21407F Block 3: Lock 1: CLOSED -> Lock Data: 21402F Block 4: Lock 1: CLOSED -> Lock Data: 21402F Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Phone not supported FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2140700000000000 Provider: Movistar (DCT3);Spain Key Code count: 3, FBUS Code count: 7 Block 1: Lock 1: CLOSED -> Lock Data: 21407F Block 2: Lock 1: CLOSED -> Lock Data: 21407F Block 3: Lock 1: CLOSED -> Lock Data: 21402F Block 4: Lock 1: CLOSED -> Lock Data: 21402F Sending code... Error unlocking! Code: 08 | |
02-04-2009, 18:17 | #10 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 407316 Status: Offline Thanks Meter: 78 | read pm, edit field 120 where try counters are stored and write that field(sub entry) back to phone, u will get 0/0 try's if ur code is right enter it by keypad, get phone unlocked btw. search forum for software to reset counters, if u don't want to play with pm urself |
02-05-2009, 19:55 | #14 (permalink) |
Member: 595735 Status: Offline Thanks Meter: 20 | a here is the good pm please can any one modify it http://rapidshare.com/files/19435462...0_255.rar.html |
02-06-2009, 00:20 | #15 (permalink) |
Insane Poster Join Date: Aug 2007
Member: 565197 Status: Offline Thanks Meter: 236 | @alick_2008 Here is Modification PM Write PM Enter Code by Keyboard http://rapidshare.com/files/19445396...fy_it.rar.html |
Is it possible to enter 6700 code by cable/fbus | James-R | Nokia Base Band 5 ( BB-5 ) | 3 | 02-12-2010 18:27 |
enter code via cable on DCT4+ | yurais | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 05-22-2008 01:28 |
Does anyone out there can unlock GX10i handset code by cable? | Qbe | Sharp | 7 | 10-31-2004 02:57 |
ericsson Tx security code by cable? | andy | Old Ericsson Phones & Sony Phones | 5 | 04-18-2000 21:19 |
ERICSSON TX security code by cable??? | andy | Old Ericsson Phones & Sony Phones | 0 | 04-15-2000 09:27 |
