09-01-2009, 13:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Please Help me big problem 3110c contact Service……… I erased whole flash with backup full pm & rpl then full flash latest v7.21, write backup rpl & pm, showing contact service my problem not solved, I sending screen short & selftest log. Using device: J.A.F, FW ver: 01.B1 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM1 ID: 00000232 EM2 ID: 00000353 PUBLIC ID: 04D0001048C27D56DCECC80D7DF04E8B4AACC694 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel ] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D Original Imei: 35683302921959Original Product code: 0550573 Bluetooth ID: 0022FDF8F666 Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35683302921959-3 Product Code: 0550691 VariantId: M Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei: 356833029219593 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Phone Type: RM-237 SW version: V 07.21 05-11-08 RM-237 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y !failed !12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N passed 2 CURRENT_CONS N passed 42 RADIO Y passed 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 71 BT_WAKEUP N passed 99 IRDA_LED_STRESS N passed 96 HOOKINT N passed 88 TAHVOINT Y !no signal 56 SLEEPCLK_FREQ N passed 101 BTEMP N passed 107 BT_SLEEP_CLK N passed 108 EXT_DEVICE N passed 86 CDSP_RF_BB_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 85 CDSP_TX_IQ N !no signal 74 CDSP_TXC_DATA N !no signal 79 CDSP_RX_PLL_PHASE_LOCK N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal |
09-01-2009, 15:29 | #2 (permalink) |
No Life Poster Join Date: Sep 2004 Age: 49
Member: 81501 Status: Offline Thanks Meter: 41 | full flash the phone write backup rpl and 308 pm then sx4auth then write modified pm (not your backup pm) , problem will solve if phone restricted unlock/repair sl................ |
09-01-2009, 16:24 | #3 (permalink) |
Freak Poster Join Date: Apr 2009 Location: PAKISTAN , LAHORE Age: 42
Member: 1021182 Status: Offline Thanks Meter: 39 | use UFS HWK AND WRITE LATES FLASH AND GOOD PM AND UI SETTINGS YOUR PROBLEM IS SOLVED IF THE SET IS IN SOFTWEAR PROBLAM IF ITS HARDWEAR PROBLAM THEN ONLY RE HOT ON FLASH IC AND THEN FLASH IT LOW VER FLASH FILE AFTER IT ERASE IT AGAIN AND THEN LATEST FLASH AND UI SETTING AND GOOD PM NOW YOUR SET IS OK ABDULLAH81 |
09-02-2009, 07:00 | #5 (permalink) | |
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Quote:
I tried you given the solution but same problem, please give me another sollution, i repaired many phones bb5 contact service but this set is not solve problem, thanks. | |
09-09-2009, 07:16 | #7 (permalink) | |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | Quote:
bro,its 100% hardware probleam rehot power ic (retu) or change this then post resuld [email protected] | |
09-10-2009, 08:42 | #8 (permalink) | |
Thanks Bro, Succesfully Repaired my phone with this solution, i reflowd retu then contact contact service is gone. | |
please help me big problem n72 phone start-up failed contact the retailer........ | swechacnu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 10-07-2009 17:31 |
Please Help Me, Big problem with 5130 Contact Service......... | swechacnu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 10-02-2009 20:04 |
6610i contact service after write pm please give me pm for remove contact service | shivam4you | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 12-19-2008 07:50 |
2 x 6300 big problem ,both contact service after unlock | kaholukkk | BB5KING for (BB5BOX) | 3 | 11-18-2008 23:40 |
Big problem V66 CONTACT SERVICE PROVIDER | G$M solution | Motorola P2k | 2 | 03-09-2002 17:19 |
