09-01-2012, 23:21 | #1 (permalink) |
Insane Poster Join Date: Aug 2009 Location: Pakistan
Member: 1091172 Status: Offline Thanks Meter: 7 | plezzzz help me nokia e7 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100148F Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14102(15-06-2012) Processing MCU file: RM-626_111.040.1511_79u_prd.core.fpsx [BB5,XSR 1.6] size: 123.44 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 12F00104C5D603447B00EB43BEB291C00DB83D2F CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1D531B6E FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x0 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x0 bytes). Reading CMT HWC (0x0 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Invalid Certificate Data, backup will not be created. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 508.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0FC7FFFF] CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT SOS+DECOMP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 8EABFDA6 [RAP Certificate v1 248] sent CMT GENIO_INIT block sent CMT SOS+IVE3A block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 26.641 s Processing PPM file: RM-626_111.040.1511_30.01_MEA_A_LatinQwerty_79u_prd.r ofs2.fpsx [BB5,XSR 1.6] size: 50.93 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 67.50 MB CMT FLASH,MuxOneNAND area [0A580000-0E8FFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 11.656 s Processing PPM file: RM-626_111.040.1511_C05.01_MEA_79u_prd.rofs3.fpsx [BB5,XSR 1.6] size: 43.97 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 19.66 MB CMT FLASH,MuxOneNAND area [01378000-0139FFFF] CMT FLASH,MuxOneNAND area [0E900000-0FC7FFFF] Flash programming ... CMT SOS+ROFS3 block sent CMT SOS+IVE3B block sent Programming completed in 0.078 s Processing CNT file: RM626_APE_ONLY_ENO_11w36_v0.037.fpsx [BB5,XSR 1.6] size: 4.56 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 1.219 s Processing CNT file: RM-626_111.040.1511_U02.01_79u.uda.fpsx [BB5,XSR 1.6] size: 212.45 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 484.50 MB CMT FLASH,MuxOneNAND area [0FC80000-2E0FFFFF] Flash programming ... Error while programming [00] at 0x0FC80000, Result: 0000 FULL FACTORY... Failed! (03E5) Completed in 5.906 s |
