04-08-2009, 03:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | posible way to write pm 120 amd 308 w/o sx4 let me know if ti works 1.-make a crt backup as rpl 2.-flash this blank rpl atached here 3.-write unlocked 120 and 308 pm fileds ( after write blank rpl you can without sx4 auth ) 4.-write crt as rpl original backup to get your original imei please share results and post log for research pd. this procedure works with 5300 phone not tested in sl2 rapido phones based |
04-08-2009, 04:09 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Dominican Republic
Member: 482218 Status: Offline Thanks Meter: 119 | theres is a method but its kinda dangerous for rapido phones. doing full crt and pm backups then do contact retailer procedure, full erase then full flash and write backups. btw this method sometimes fixes few other things that normally are considered hardware faults, i had a n73 that wouldnt charge then repaired it with that method. |
04-08-2009, 05:18 | #5 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 745804 Status: Offline Thanks Meter: 33 | you cannot use this method or solution,,,,, after restoring back the original RPL, it will return back to original state. so u still have to use the proper procedure with sx4 auth |
04-08-2009, 06:40 | #6 (permalink) | |
Member: 103024 Status: Offline Thanks Meter: 616 | Quote:
the other way posted before do the same and its very good for repair any sw problem because all flash chips are erased and nobody can determine to enable security on pm fields , so the real solution doesnt is tell if works or not simply let try on a phone and post the log to see results | |
04-08-2009, 06:57 | #7 (permalink) |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | not working .... i tested by old gt method but it not working dud bcoz in some phone 5800 n85 n96 ... etc 120 308 pm Area write protected o answer simply not working br.DYNET Code: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 01 F3 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Powering the phone... Writing PM... Field: 120, Record: 0, Len: 56 -> OK Field: 308, Record: 1, Len: 8192 -> Error: Need SX4 auth.. Done! BR.DYNET |
The Following 2 Users Say Thank You to DYNET For This Useful Post: |
04-11-2009, 17:47 | #9 (permalink) | |
Member: 482218 Status: Offline Thanks Meter: 119 | Quote:
contact retailer procedure is probably the way. instead of writing original pms, write new unlocked ones after writing blank rpl. i have done this with N82 model. as i said is dangerous with rapido phones. btw n82 was bricked already, surgery was succesfull but patient didnt make it LOL. | |
04-11-2009, 20:11 | #10 (permalink) | |
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | Quote:
in my case i don't have back up on same time :d | |
04-12-2009, 20:58 | #15 (permalink) | |
Freak Poster Join Date: May 2005 Location: Thailand
Member: 143711 Status: Offline Sonork: 100.1620786 & 100.1579470 Thanks Meter: 7 | Quote:
Today I test not work too ...with 6220c | |
Plz check manole do every thing now able to write pm 1 and 309 | rajan nishchal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-29-2010 15:20 |
help me what is pm 120 and 308 | abheejeet | Nokia Base Band 5 ( BB-5 ) | 0 | 10-25-2009 06:52 |
what is pm 120 and 308????????? | sunmob_1980 | Nokia Base Band 5 ( BB-5 ) | 18 | 09-24-2009 15:15 |
n96 Failed to write PM block: 308 | mohitgsm | Universalbox | 8 | 03-27-2009 10:23 |
