Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 05-23-2007, 01:31   #1 (permalink)
amar22ado's Avatar
Member: 230087
Post Here The Method You Use In Preventing/solving The Problem In Bb5 Unlocking
I WILL START, HERE IS MINE AND HOPE IT WILL HELPS OTHERS.
6630 - FIRST I BACK-UP ITS PM USING HWK THEN I UNLOCK IT WITH DEJAN SOFTWARE. ON PRESSING MAKE LOG, IT WAS NOT SUCCESSFUL AND ITS SP DATA CORRUPTS (4-CLOSED LOCK!). I SIMPLY REFLASH ITS PM AND UNLOCK IT AGAIN. IT WAS SUCCESSFUL! PROBLEM ENCOUNTERED, PROBLEM SOLVED!
Old 05-23-2007, 01:43   #2 (permalink)
lxa786's Avatar
Member: 163725
6630
Hi,
i try to unlock 6630 but i get an error sp data is corrupted. please can you send me the pm flash thanks
Old 05-23-2007, 02:48   #3 (permalink)
potzilla's Avatar
Member: 168612
[QUOTE=lxa786;2460873]Hi,
i try to unlock 6630 but i get an error sp data is corrupted. please can you send me the pm flash thanks[/QUOT
have you back up your phone? try to remove phone from cable and start the prcedure again.
1.)read phone
2.)make log
3.)sp unlock
4.)bb5 cal.
5.)spunlock
good luck.
Old 05-23-2007, 05:47   #4 (permalink)
alayne's Avatar
Member: 162029
Hope this would help.
I used jaf box with com emulator for stable cable communication and it sets phone to local mode so it is lesser to commit errors in sending data to phone and it doesn't use battery also for safety.
Old 05-23-2007, 09:09   #5 (permalink)
Registered User
to_deal_with's Avatar
Member: 19168
The Solution I have tested to prevent SP Data corruption.
- Phone off,
- Connect the cable to phone anc pc (dku5, jaf, serial)
- Open the program
- Power on the phone
- When you see Nokia on the screen, immediatly press on Make Log!
Afterwards BB5 Calc and then SP Unlock
This method has always been a success.
If I power on the phone first and let it start up completely, by inserting the cable phone says enhancement not supported and making log fails.
In this case, reconnect the cable and Press Write backup.
If writing backup succeeded, Just follow the method I wrote above. Tested on many N70.
Old 05-23-2007, 09:14   #6 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Sonork: 100.1577222
Yep thats the 100% Working way to prevent that 4ucking **** ibeen going through messed up from others
Old 05-23-2007, 09:27   #7 (permalink)
Member: 201126
hi friends
i also have two 6630 with sp area corrupted
i flash it butt the problem is same
what i do???????
any other solution please help me
Old 05-23-2007, 09:33   #8 (permalink)
btl
btl's Avatar
Member: 50389
the best way is using the original dk soft even when there is an error it easily resolved by pressing the restore button many times u can use jaf and ufs if u want but the most effective and reliable means is the dk soft cos i have had probem like contact service and dp data currupt but solved
Old 05-23-2007, 15:42   #9 (permalink)
amar22ado's Avatar
Member: 230087
Originally Posted by Buttsb View Post
hi friends
what i do???????
Here is the solution for SP DATA ERROR, downgrade its firmware by using the downgrade button then unlock it. That should solve the problem. (don't forget to reply....)
Old 05-23-2007, 22:50   #10 (permalink)
Member: 150570
Still the best way to repair, has not failed me once
About "BB5 SP data corrupted"
Marty
Old 05-24-2007, 02:22   #11 (permalink)
ekotek's Avatar
Member: 506781
Sonork: looking for a job
I have tried to SP lock 6280, and failed... actualy now i have no backup etc. i got message contact service, the only problem and not solved
Old 05-27-2007, 02:48   #12 (permalink)
Member: 427577
Old 05-27-2007, 03:17   #13 (permalink)
Un|ocker's Avatar
Member: 511890
This model is unsupported mate. Read the original post when dejan gave us this software
Old 05-27-2007, 04:32   #14 (permalink)
salamatali's Avatar
Member: 476774
Be sure that my BB5 logger is installed properly with apropriate FBUS interface
(DKU-5) or old clasic FBUS cable connected to standard COM port.
Start loger.
Once connected phone by FBUS interface to PC, press "Read Phone" button.
If everything is ok, some data will be readed and displayed, otherwise check
your connection, phone, cables, etc.
If logger shows message "SP Data IS corrupted" than you have phone that
somebody played with it and destroyed field 308,1. So, you have to fix
that field by sending that phone to official NOKIA repair centre!!!
If everything is OK you can press "Make Log" button.
LOGER will create backup of field 308,1 and try to make LOG file.
In that proces, some time field 308,1 can be corruted which can be checked
by clicking again on "Read Phone" button.
NOW, if logger shows message "SP Data IS corrupted" than you just have
to click several times "WR Backup" and "Read Phone" to check that is your
phone is OK
best regard
salamat ali
Old 05-27-2007, 06:39   #15 (permalink)
Angelo Cruz's Avatar
Member: 8012
salamat ali.... what the f*u*c*k?
copy , paste ?
What´s the point?
please can you solve this problem in n90 walidb Nokia Hardware & Hardware-Repair Area 1 06-26-2009 17:49
<<<<<what Method You Use For Samsung>>>>>>>> falak Easy-Unlocker 5 02-12-2008 15:24
Page generated in 0.57036 seconds with 12 queries
