problem nokia n73 phone start-up failed. Contact the retailer. when applying flash to this model, appears to me that, and also this. Reading... MCU SW version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. HW version: 7200 PCI version: RFIC version: 17211721 DSP version: scarfe_mc.05wk46v50p2 Retu version: 15 Tahvo version: 22 Production serial number: CDE710461 Product code: 0515621 Module code: 0202856 Basic production code: 0545048 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 354804014899774 IMEI spare to net: 3A 45 08 04 41 98 79 07 IMEI SV to net: 33 45 08 04 41 98 79 77 F8 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 as I solve this? |
Relock And Unlock Or Repair SL......... |
write new rpl to solve it............. |
If you do not have backup pm or RPL bacup, then you will have to buya new RPL |
not have backup pm or RPL bacup, there is some way to repair it? |
try to use zulea Repair SL option. |
it seems that your IMEI is still good make a back for it then do ERASE but dont include PM area do full flash, repair sl zone, write your bck up RPL |
boss try use bb5 prince for contact retailer repair sl then unlock, , , , , http://www.mediafire.com/?sharekey=f...e6ba49b5870170 |
Only RPl file can help you! |
i have n73 when power on show message phone startup failed contact the retailer.some time it working but some time show phone startup failed contact the retailer.i think its hardware fault.some body help me JAF version 1.98.62 Detected PKEY: 9000CA92 Card life counter: 99.99% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. HW version: 6000 PCI version: RFIC version: 17191719 DSP version: scarfe_mc.05wk46v50p2 Retu version: 15 Tahvo version: 21 Production serial number: SBH144666 Product code: 0529607 Module code: 0202855 Basic production code: 0527006 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 359738003248616 IMEI spare to net: 3A 95 37 08 30 42 68 01 IMEI SV to net: 33 95 37 08 30 42 68 71 F8 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-133.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0529607 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-133\ Searching for default location of ini... Checking path: \Products\RM-133\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-133\ Scanning ini files... Searching for default location of ini... Checking path: \Products\RM-133\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-133\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_3.0705.1.0.31_western_C00_PRD_cc.fpsx PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_rofx_3.0705.1.0.31_PRD.V11 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_userarea_3.0705.1.0.31.U01 APE Variant file: NONE Languages in ppm: English,Simpl Chinese Done! |
Relock And Unlock try and post |
n73 phone startup failed contact the retailer hlp 9978509801 SOLUTION |
n73 phone startup failed Quote:
