02-06-2012, 11:42 | #31 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Tanzania Age: 62
Member: 22542 Status: Offline Sonork: 100.1660285 Thanks Meter: 102 | Quote:
02-09-2012, 09:45 | #36 (permalink) |
Member: 22542 Status: Offline Sonork: 100.1660285 Thanks Meter: 102 | Flashed with Best dongle:card found: S/N XXXX:XXXX registered to: Benny Haraba Connect phone on selected interface... UFS S/N XXXXX boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core version : 1.36 Rev : 1.3 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : N73_4.0736.3.2.1_western_C00_PRD_cc.fpsx PPM : N73_rofx_4.0736.3.2.1_PRD.V02 Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 79108095D5DF0BF141BE65D2F9F07DC8E4A68AFE APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1F30021256F36A50317F1728CE5E4E922656D0A4 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 30600 byte(s) IMEI : 358634016928669 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 30600 byte(s) APE : Read NPC certificate... Cert size : 0 byte(s) APE : Read CCC certificate... Cert size : 0 byte(s) APE : Read HWC certificate... Cert size : 0 byte(s) APE : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... VARIANT Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358634016928669_CR T_2nd.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 79108095D5DF0BF141BE65D2F9F07DC8E4A68AFE APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1F30021256F36A50317F1728CE5E4E922656D0A4 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_4.0736.3.2.1_western_C00_PRD_cc.fpsx Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00080000 - 0x007314D1 CMT , NOR , Area : 0x00000000 - 0x0005FFFF CMT , NOR , Area : 0x001E0000 - 0x001FFFFF CMT , NOR , Area : 0x00880000 - 0x00FEFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0007FFFF APE , NAND , Area : 0x00080000 - 0x000FFFFF APE , NAND , Area : 0x00100000 - 0x0025FFFF APE , NAND , Area : 0x003C0000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:46 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_4.0736.3.2.1_western_C00_PRD_cc.fpsx CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ADL] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [SOS*UPDAPP] APE: Writing Hash CERT [SOS+UZIP] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [ADL] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [SOS*CORE] Total writen 1736 blocks TIME : Write time : 00:05:26 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_rofx_4.0736.3.2.1_PRD.V02 Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x03920000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_rofx_4.0736.3.2.1_PRD.V02 Total writen 1993 blocks TIME : Write time : 00:02:44 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia N73 Software Info: V 05wk47v51.5 29-08-07 RM-133 (c) Nokia. IMEI: 358634016928669 Product code: 0529607 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
02-09-2012, 18:46 | #37 (permalink) |
Member: 22542 Status: Offline Sonork: 100.1660285 Thanks Meter: 102 | EVEN WITH HIGHER VERSION DOES NOT WORK RATHER SOLVE THE PROBLEM HERE ARE LOGS : card found: S/N XXXX:XXXX registered to: Benny Haraba Connect phone on selected interface... UFS S/N 60688 boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Read and Check phone data... SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL phone detected Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 79108095D5DF0BF141BE65D2F9F07DC8E4A68AFE APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1F30021256F36A50317F1728CE5E4E922656D0A4 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU cfg fail!!! Error : F37272 Error : info stage failed - check connection , HW Init Service mode... Wait... Core version : 1.36 Rev : 1.3 Selected FlashSettings : FullFlash Files Set for Flashing : MCU : N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx PPM : N73_rofx_4.0850.43.0.1_PRD.V11 CNT : N73_userarea_4.0850.43.0.1.U01 Check FlashFiles, Please, wait... -> SWversion check skipped : Manual mode selected Backup enabled, Will read Certificates now... CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 79108095D5DF0BF141BE65D2F9F07DC8E4A68AFE APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1F30021256F36A50317F1728CE5E4E922656D0A4 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 30600 byte(s) IMEI : 358634016928669 CMT : Read CCC certificate... Cert size : 0 byte(s) CMT : Read HWC certificate... Cert size : 0 byte(s) CMT : Read VARIANT certificate... Cert size : 30600 byte(s) APE : Read NPC certificate... Cert size : 0 byte(s) APE : Read CCC certificate... Cert size : 0 byte(s) APE : Read HWC certificate... Cert size : 0 byte(s) APE : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... VARIANT Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\358634016928669_CR T_2nd.rpl Setting FlashMode FlashMode set Ok 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 79108095D5DF0BF141BE65D2F9F07DC8E4A68AFE APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 1F30021256F36A50317F1728CE5E4E922656D0A4 CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg , Rev : 0.0 Ver : 10.42.0 CMT Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 03 FLASHID : 22E800EC , CMT , NOR CMT Flash ID : 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLCNT : 00000000000000000000000000000000000000 FLASHID : 0000FFFF , CMT , MMC , EXT CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok Sending ALGO.... Use : RAP3Gv3_algo.fg , Rev : 0.0 Ver : 10.40.0 CMT Algo sent CMT PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBD Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg , Rev : 0.0 Ver : 1.35.0 APE Loader sent, Boot Ok MCU Configuration MCU Cfg Ok , 02 FLASHID : 00A100EC , APE , APE Flash ID : 00A100EC < SAMSUNG [SEC] => K5E1G12ACM [NAND] FLCNT : 010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Sending ALGO.... Use : h3_sam_nand_xsr.fg , Rev : 0.0 Ver : 1.47.0 APE Algo sent APE PAPUB : 5E8D0D504A0902E261268C14FCD8A2C9093523BCBC Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00080000 - 0x0073194D CMT , NOR , Area : 0x00000000 - 0x0005FFFF CMT , NOR , Area : 0x001E0000 - 0x001FFFFF CMT , NOR , Area : 0x00880000 - 0x00FEFFFF Using TimeOut : 7 min ( 430 sec ) Erasing, wait..... CMT : Group erase Ok Found 4 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0007FFFF APE , NAND , Area : 0x00080000 - 0x000FFFFF APE , NAND , Area : 0x00100000 - 0x0025FFFF APE , NAND , Area : 0x003C0000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:46 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ADL] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [SOS*UPDAPP] APE: Writing Hash CERT [SOS+UZIP] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [ADL] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [SOS*CORE] APE: Writing Hash CERT [SOS+ROFS] APE: Writing Hash CERT [SOS+ROFX] Total writen 1704 blocks TIME : Write time : 00:05:18 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Partitioning.... Partitioning Ok... Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_rofx_4.0850.43.0.1_PRD.V11 Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x03920000 - 0x04E1FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_rofx_4.0850.43.0.1_PRD.V11 APE: Writing Hash CERT [SOS+ROFX] Total writen 1987 blocks TIME : Write time : 00:02:43 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Erase : Processing N73_userarea_4.0850.43.0.1.U01 Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x04E20000 - 0x07C9FFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:00 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Transmission mode : Dual (Ddr, TX2) Write : Processing N73_userarea_4.0850.43.0.1.U01 Total writen 164 blocks TIME : Write time : 00:00:34 PrReq : NOR , 00 PrReq : NAND , 01030000504A0900E261260014FCD8 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia N73 Software Info: V 05wk47v62 05-12-08 RM-133 (c) Nokia. IMEI: 358634016928669 Product code: 0529607 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... AfterFlash operations done ;D Connect phone on selected interface... Connect phone on selected interface... Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
01-12-2014, 03:49 | #40 (permalink) |
Insane Poster Join Date: Jul 2012 Location: apple mobile durbar main gate
Member: 1790945 Status: Offline Thanks Meter: 6 | i always do verry simple steps to reomove contact the retailer in n73 ....backup rpl ,erase whole flash by atf ,then flash by ufs and write rpl by atf and repair simlock ....easy steps and worked on every n73 handsets came on contact the retailer problem 10000% working ....... |
Nokia N73 Phone start-up failed contact the retailer | powerplay83 | Universalbox | 10 | 12-10-2009 23:39 |
N73 Phone start-up failed. Contact the retailer. | E-Tech | Nokia Base Band 5 ( BB-5 ) | 0 | 12-09-2006 23:42 |
