05-17-2007, 21:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: UK -Leicester
Member: 51517 Status: Offline Thanks Meter: 24 | Serial Com port to Nokia Pop Port Cable (for BB5 unlock) - Tested best of all...no drivers needed, just a PC/Laptop with a COM port!! (and some soldering skills) p.s. i recommend using a DIL chip holder for the MAX232 chip to prevent damage to it! Note: double check the orientation of the Capacitors and make sure they are rated at 16V or higher. Schematic Strip-board Layout - Front Strip-board Layout - Back Enjoy! Last edited by LAD; 05-18-2007 at 05:25. Reason: updated schematic |
The Following User Says Thank You to LAD For This Useful Post: |
05-17-2007, 23:39 | #5 (permalink) |
Freak Poster Join Date: Feb 2007 Location: HERE IN SOME ROAD
Member: 447104 Status: Offline Thanks Meter: 17 | lol - Good luck with your exams! I've got an FBUS cable but for some reason it is not working with N70, but works with 7250 lol ***put two diods zener 2,7v from gnd to both rx and tx and ur cable will be ok |
05-18-2007, 02:25 | #6 (permalink) |
Junior Member Join Date: Apr 2007
Member: 488245 Status: Offline Thanks Meter: 0 | thanks for the strip board version man one question... i have a CA-53 here, but i don't wanna cut it for the connector, can i use a USB female as output of the circuit and use ca-53 without cutting down it? it seems be pin-to-pin cable. Thanks Last edited by krasny; 05-18-2007 at 02:39. |
05-18-2007, 02:50 | #7 (permalink) | |
Member: 51517 Status: Offline Thanks Meter: 24 | Quote:
For the pop port side of the cable, i actually took it from a basic serial cable ( just has wires, no circuit) which i has bought years back, and de-soldered the connectors from that...they are on ebay for a few quid, i'd just recommend getting one one of them, and building from that. NOTE: you will still have to buy the D-Sub 9 connector cus usually the connector on the cheap cables off ebay only have 3 wires with molded plastic around the connector, so u can't really use that! Good luck | |
05-18-2007, 06:26 | #8 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 44
Member: 162029 Status: Offline Thanks Meter: 202 | There are 2 kinds of dku5 cable in the market. 1 with complete pins the others seems like 5/6 only. the first 1 works and tested it by myself. we all use it on all of our 5 shops. |
05-18-2007, 10:02 | #10 (permalink) |
Junior Member Join Date: May 2003 Location: TUNISIA
Member: 29749 Status: Offline Thanks Meter: 1 | Look for this post it is more easier to make com port with USB cable : http:///vbb/showthread.php?t=403373 |
05-20-2007, 19:31 | #13 (permalink) |
Member: 488245 Status: Offline Thanks Meter: 0 | Ok, thanks for replies... one question, why you cut the center lead of the transistor? I made it this afternoon, but it don´t work, tomorrow i will test it again. What programa did you use to make the schematics? Thanks! |
05-21-2007, 22:41 | #15 (permalink) |
Member: 51517 Status: Offline Thanks Meter: 24 | i did it manually!! the first circuit schematic is just a re-edit of the original (which didn't look as nice and less clear in my view!) the strip board scematics, i originally made another circuit about a year ago in a desktop publishing program called pageplus (VERY VERY GOOD PROG!) and just edited it for this circuit! took about 1.5-2 hours though :S good to hear |
Nokia pop port stereo output (6630) | IvailoShopov | Nokia Hardware & Hardware Repair | 0 | 11-17-2006 01:12 |
Nokia Pop-Port Security code reset solution | ekalman | Nokia Hardware & Hardware Repair | 6 | 12-28-2004 00:40 |
Nokia Pop Port | Magic2ik | Nokia Multimedia | 1 | 12-15-2004 15:24 |
New Nokia Pop-port UFSx cable schematic | Macfox | UFS2 + UFS3-Tornadoflasher | 0 | 07-12-2004 08:47 |
