12-06-2009, 16:45 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside MTK Age: 38
Member: 248182 Status: Offline Thanks Meter: 786 | 5130C Super DONGLE KEY DAMAGED But FULL RPL OK BACKUP EXIT one month ago i received 5130c with blinking problem so i flash phone after that phone will be ok.. so i made full backup with mx-key (full rpl + full pm) After month again i received that set in contact service problem but interesting thing is that super dongle key missing. So I write Full ok Backup including pm via mx-key but after write still same condition This phone have protected pm 308 ..... so during restoring pm 308 ..it unable to write pm 308. can we write pm 308 @ SL3 Phone via cross flashing ???? Tomorrow i will post you all logs of this ALL Suggestion is appreciate able ... Rgds bluffmaster |
12-07-2009, 06:47 | #5 (permalink) | |
Junior Member Join Date: Dec 2009 Location: batam island
Member: 1175373 Status: Offline Thanks Meter: 1 | Quote:
2: write pm backup area 308 3: flash back using 5130c 4: pmm auth and skip area 308 with mxkey 5: just be carefull,,,,, | |
The Following User Says Thank You to vanzphonerepair For This Useful Post: |
12-07-2009, 12:35 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
- Do selftest and check If (ST_Simlock_Failed) means you will have to load simlock_data and simlock_data_key. As you know simlock cannot be written in PA_SL3 except tucsan rpl and mx-key to upload. - If (ST_Security_Failed) means you will have to load superdongel data. You can repair this data using MT,UB. It can be written in PA_SL3 using normal rpl. - If both are damaged so you have to buy Nokia tucsan rpl. BR, Ali | |
12-09-2009, 17:04 | #7 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | Quote:
you save then, since your location says you in the right place. NO Need MT or UB or a single dime for your case | |
5130c super dongle invalid | pallumobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 02-16-2010 10:43 |
mx key super dongle key sucessfull video it is ok | .::VENUGOPAL::. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-13-2010 06:51 |
e63 full backup but unable to update super dongle key | bluffmaster | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 10-26-2009 11:44 |
E63 full backup unable to restore super dongle key | bluffmaster | HTC CODE WORLDWIDE | 0 | 10-26-2009 09:00 |
